Yoto Generation 3 Mobility Adaptation
  1. Yoto Generation 3 Mobility Adaptation, Peel plastic overscreen: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gen 3 Specific- Gently peel the screen off the METAL splunger tool from ifixit. Run it around the inner plastic. Also turn your yoto off unless you want to be blinded
    • Gen 2- follow the SD guide provided online by Yoto. Return at the step after the rotary encoder is removed.
  2. Yoto Generation 3 Mobility Adaptation, Unscrew LED motherboard cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Keep your yoto off. There's about 200 screws. Unscrew them. Then pry off with the good ole metal spludger. Then gently pry up the green motherboard.
  3. Yoto Generation 3 Mobility Adaptation, Gently remove button and unscrew the rotary encoder: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pop off the button by gently wedging the spludger and wiggling the orange plastic. Then use pliars to unscrew the hex nut
  4. Yoto Generation 3 Mobility Adaptation, Unscrew and unplug: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the NFC card holder. Use the spludger to make sure there is no glue in the female connector socket on the motherboard for the NFC and the right hand button.
  5. Yoto Generation 3 Mobility Adaptation, Thread your 4 pin JST 2.0 male through the hole and plug into motherboard: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Thread your cable with shrink through the hole, Attach to motherboard. Put NFC back in and reassemble Yoto. This is the same for the Generation 2.
    • Now is the time to put the jacket back on.
  6. Yoto Generation 3 Mobility Adaptation, Connect to 3D printed parts: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Connect to female side of cable and insert the rotary encoder into the 3d printed part. it is a tight fit so be sure to go slow and secure tighlty
  7. Yoto Generation 3 Mobility Adaptation, Connect the button to the Yoto: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Connect the wires. Yellow to yellow, red to read, black to black and white to white. Coer with heat shrink tubing. You can solder or just twist.
RaeL
crwdns2935283:011/17/24crwdne2935283:0
358 crwdns2915208:0crwdne2915208:0
Thank you! This is the only set of instructions I've found for how to open up a 3rd gen Yoto! I order the spudger set and the tool worked perfectly.
yotorocks - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 115
crwdns2942667:0crwdne2942667:0 945
