Yashica T5D Shutter Flex Cable Replacement
  1. Yashica T5D Shutter Flex Cable Replacement, Disassembly front case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Yashica T5D Shutter Flex Cable Replacement, Disassembly front case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Install the battery, turn on the device, and wait for the lens to extend. Use rubber gloves or finger covers and gently unscrew the lens ring counterclockwise.
    • Unscrew the three screws that secure the dust cover.
    • After completion, turn off the device and make sure the lens retracts normally.
  2. Yashica T5D Shutter Flex Cable Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery and gently peel off the sticker in the battery compartment.
    • For the D version camera, there is a ribbon cable underneath the sticker, so be careful to separate it gently.
  3. Yashica T5D Shutter Flex Cable Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Yashica T5D Shutter Flex Cable Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Yashica T5D Shutter Flex Cable Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the three screws inside the battery compartment.
    • Open the film compartment and unscrew the five screws, noting that one marked with an "H" is hidden under a spring clip. The screws are of different lengths and need to be labeled for reference when reinstalling them.
    • Unscrew the three screws at the bottom.
  4. Yashica T5D Shutter Flex Cable Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • There are several clips on the front cover that can be gently pried open using a plastic pry bar along the crevices. Slowly slide open the front cover.
    • There is a line of waterproof rubber around the edge of the front cover, and wires are also present. When using tools, do not insert too deeply. (Please refer iPod disassembly for more information)
  5. Yashica T5D Shutter Flex Cable Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unsolder the four wires marked with No.1 yellow marker.
    • Unsolder the four wires marked with No.2 marker.
    • Unsolder the date cable with three contacts marked with No.3 marker.
    • Unsolder the lens cable with three contacts marked with No.4 marker.
    • Unsolder the button cable with three contacts (this machine may have been repaired in the past and used flying wires) marked with No.5 marker.
  6. Yashica T5D Shutter Flex Cable Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Yashica T5D Shutter Flex Cable Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull outwards to remove the left cover plate.
    • Unscrew 2 screws.
  7. Yashica T5D Shutter Flex Cable Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Yashica T5D Shutter Flex Cable Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently lift the internal part from the right side. Be careful not to break the upper function cable (normal machines have soft cable, unlike mine) and date cable (date cable should bent and placed in the gap between the capacitor).
  8. Yashica T5D Shutter Flex Cable Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Yashica T5D Shutter Flex Cable Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the 2 screws under the red circle, which are the two rows of wires used to connect the lens and the main board.
    • Unsolder the 5 contacts that connect to the flash unit.
  9. Yashica T5D Shutter Flex Cable Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Yashica T5D Shutter Flex Cable Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Yashica T5D Shutter Flex Cable Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Solder off the negative battery wire.
    • Unscrew 2 screws.
    • Solder off the positive battery wire.
    • Takeoff the flash light/power module.
  10. Yashica T5D Shutter Flex Cable Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Yashica T5D Shutter Flex Cable Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the screw labeled 5.
    • Use a tool to remove solder from the contact with number 6.
    • The double stick tape on the left is distributed in from 1 to 4.
    • First gently remove the contacts of buttons 1 and 2 and take them off of the slot.
    • Then use a tool to gently take off the main board with number 3.
    • Note that there are also components on the back of the main board, so be careful not to break them.
  11. Yashica T5D Shutter Flex Cable Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Now the main board should be lift like this.
    • At this point, the mainboard and the viewfinder module are still connected together, and this part does not need to be disassembled. Is enough for replacing the lens cable.
  12. Yashica T5D Shutter Flex Cable Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift up the LCD screen and shutter button from both sides (be careful of the adhesive), unscrew the 2 screws marked.
    • The viewfinder and main board can be completely take off.
  13. Yashica T5D Shutter Flex Cable Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Yashica T5D Shutter Flex Cable Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Yashica T5D Shutter Flex Cable Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the 6 screws, paying attention to the 2 screws on the side.
    • Take off the lens module.
    • Pic2: Unscrew the 2 screws, gently peel off the adhesive on the upper left corner, and remove the light shield.
    • Pic3: Unscrew 3 screws to take off the lens and shutter module.
  14. Yashica T5D Shutter Flex Cable Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • This is Shutter FPC Cable.
    • Use the resistance scale of a multimeter to test the five contacts and the gold fingers of the cable. If the resistance is infinite, it indicates that the cable is broken.
    • Additionally, the two thin wires connected to the shutter motor at the bottom should be connected directly to the gold fingers and measure as continuous.
  15. Yashica T5D Shutter Flex Cable Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Be mindful of the original cable's bend and installation position, and use double stick tape to secure it.
    • Some parts require lubrication, so apply a small amount of grease.
    • Avoid using a liquid lubricant to prevent it from seeping into the shutter and causing malfunction.
  16. Yashica T5D Shutter Flex Cable Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Yashica T5D Shutter Flex Cable Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • When reassemble, follow the disassembly sequence (it is recommended to record a video to review and find any missed information such as how to place wire).
    • For the date cable on the D version, you can use a strip of paper with adhesive on one end to pull it back.
javamonk
crwdns2935283:004/02/14crwdne2935283:0
465 crwdns2915208:0crwdne2915208:0
crwdns2947412:07crwdne2947412:0
Awesome guide! I have a couple T4 and T5 cameras I'm working on, but I haven't found the culprit yet. A lot of them had leaky capacitors near the viewfinder, with one camera having a bunch of corroded traces due to the spilled electrolyte. Wiring jumper cables and installing a new cap seemed to solve the issue on this camera.
The other cameras have the same issue (lens move back in completely when the camera is powered off, and the lens sometimes gets "stuck" when the shutter is fired), but replacing the cap didn't fix the issue.
The shutter flex cables all measure out fine. Have you been able to find any other common issues with these cameras? I'd love to know and see if that fixes one or two of my Yashicas!
Leonhard Bokowski - crwdns2934203:0crwdne2934203:0
My camera was sometimes "stuck" before, the track on flex sometimes not connection well(and "stuck").
You can measure the 5 thick tracks on flex using a multimeter, twist the cable check if the connection stable.
And inside the lens, there's a optoisolator sit on flex, if the shutter not open, or the optoisolator fail, lens will "stuck" too.
javamonk -
Hey Javamonk! Really really really appreciate you taking the time to make this guide. This is huge! I'm curious if you've come across an T4 Zooms that have an issue where, even with fresh batteries inserted, the battery alert remains blinking.
greystephenson - crwdns2934203:0crwdne2934203:0
Thank you for paying attention to my manual. T4 also has the battery alert problem. I have tried before but nothing solutions found. It has been shelved for a long time. Maybe I will try again in the future. Will update if I have more information :D
javamonk -
Hello Javamonk, thank you so much for this guide. The details with pictures are amazing. Your details make it easy to follow along. Do you know a website where I can buy a replacement flex cable?
Thank you,
Ari
Ari Mermer - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 33
crwdns2936753:030crwdne2936753:0 148
crwdns2942667:0crwdne2942667:0 2,342
