Yamaha YPG-225 Keys Replacement
  1. Yamaha YPG-225 Keys Replacement, Batteries: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the keyboard over so that the keys are facing the ground.
  2. Yamaha YPG-225 Keys Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pop the tabs on the battery casing and remove it from the back plate.
  3. Yamaha YPG-225 Keys Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the six batteries and remove them from the battery cavity.
    what type of batteries? and how much ?
    thanks godbless
    colladonelson - crwdns2934203:0crwdne2934203:0
  4. Yamaha YPG-225 Keys Replacement, Faceplate: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the six 10mm screws at the top of the backplate.
  5. Yamaha YPG-225 Keys Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the seven 12mm screws in the middle of the back plate.
  6. Yamaha YPG-225 Keys Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the eight 10mm screws from the side and the bottom of the back plate.
  7. Yamaha YPG-225 Keys Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • As the face plate is no longer connected to the body of the keyboard, be careful to not drop the body when performing this step.
    • Flip over the keyboard.
  8. Yamaha YPG-225 Keys Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Yamaha YPG-225 Keys Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lifting from the front and the back of the face plate equally, pull the face plate up and then back, away from the keyboard.
    • Be careful when removing the face plate. There are wires attached.
  9. Yamaha YPG-225 Keys Replacement, Keys: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 32mm screws that hold keys down.
    • Depending on which block of keys you wish to remove, there may be four screws instead of three.
  10. Yamaha YPG-225 Keys Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the block of keys that holds the key you wish to install.
    • To do this, apply a small force away from the top of the keys and slightly toward the floor.
    • If done correctly, the block of keys will come to a slight downward angle.
  11. Yamaha YPG-225 Keys Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Yamaha YPG-225 Keys Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Press the tab on the back side of the block of keys out and detach the black keys.
  12. Yamaha YPG-225 Keys Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the individual white key(s) or the black key set(s) that require replacement.
Kevin Green
crwdns2935283:009/18/12crwdne2935283:0
308 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 2-62, Propen Fall 2012 crwdns2935289:0Cal Poly, Team 2-62, Propen Fall 2012crwdne2935289:0
CPSU-PROPEN-F12S2G62
Excellent, Although I've got a different type of yamaha keyboard, still good inside info.
Diederick Fokker - crwdns2934203:0crwdne2934203:0
Great article. Thank you so much.
Andreas Devig - crwdns2934203:0crwdne2934203:0
The instructions were very good and easy to understand. Question on the same subject. How about keys that have popped up on the key bed.
Donald Bryant - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 21,364
