Yamaha NS-AW190BL Front Panel and Speaker Housing Replacepemt
  1. Yamaha NS-AW190BL Front Panel and Speaker Housing Replacepemt, Rear Casing: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Yamaha NS-AW190BL Front Panel and Speaker Housing Replacepemt, Rear Casing: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the six Phillips Head 1.2mm screws on the front side of the speaker.
  2. Yamaha NS-AW190BL Front Panel and Speaker Housing Replacepemt: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Yamaha NS-AW190BL Front Panel and Speaker Housing Replacepemt: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Yamaha NS-AW190BL Front Panel and Speaker Housing Replacepemt: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Crack open both parts of the casing carefully.
    • Using a plastic opening tool, wedge open the bottom of the speaker to separate the two parts of the speaker.
  3. Yamaha NS-AW190BL Front Panel and Speaker Housing Replacepemt: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Yamaha NS-AW190BL Front Panel and Speaker Housing Replacepemt: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Yamaha NS-AW190BL Front Panel and Speaker Housing Replacepemt: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the cooling foam.
    • Use a metal spudger to push the tab in on the red wire.
    • Repeat the process for the blue wire.
  4. Yamaha NS-AW190BL Front Panel and Speaker Housing Replacepemt: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Yamaha NS-AW190BL Front Panel and Speaker Housing Replacepemt: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The blue wire can now be removed from its connector.
    • Remove the red wire to free the rear casing.
  5. Yamaha NS-AW190BL Front Panel and Speaker Housing Replacepemt, Wiring: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Yamaha NS-AW190BL Front Panel and Speaker Housing Replacepemt, Wiring: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the metal spudger to bend down the metal tabs that hold the wires to the terminals. The tabs are small and in between the grooves of the terminal.
  6. Yamaha NS-AW190BL Front Panel and Speaker Housing Replacepemt: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Yamaha NS-AW190BL Front Panel and Speaker Housing Replacepemt: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the wires from the terminals.
  7. Yamaha NS-AW190BL Front Panel and Speaker Housing Replacepemt: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Yamaha NS-AW190BL Front Panel and Speaker Housing Replacepemt: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the metal spudger to bend the metal tabs that hold the connectors to the terminals.
  8. Yamaha NS-AW190BL Front Panel and Speaker Housing Replacepemt: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Yamaha NS-AW190BL Front Panel and Speaker Housing Replacepemt: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Yamaha NS-AW190BL Front Panel and Speaker Housing Replacepemt: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the wires from the terminals. Then remove the entire wire assembly.
  9. Yamaha NS-AW190BL Front Panel and Speaker Housing Replacepemt, Front Panel and Speaker Housing: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the wire assembly is removed, the entire front panel and speaker housing should be separated to replace.
Nick Ruiz
crwdns2935283:002/07/17crwdne2935283:0
331 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 17-3, Blackwell Spring 2017 crwdns2935289:0USF Tampa, Team 17-3, Blackwell Spring 2017crwdne2935289:0
USFT-BLACKWELL-S17S17G3
crwdns2942667:0crwdne2942667:0 1,788
