This guide will walk you through how to change the filter on your YORK TM9Y080B12MP11 Furnace. This guide uses an Aprilaire Model 413 Filter.
It is important to replace the filter in your furnace as overtime dust and debris will build up and will enter the air ducts and home. This can lead to polluted and dirty air which can lead to a variety of issues including potential respiratory issues and triggering of allergies. Typically, furnace filters should be replaced around every month, however this will vary.
The process laid out in this guide will have you turning off the furnace, removing the old filter, inserting the new filter and then turning the furnace back on.
This guide requires no tools or prior experience replacing or fixing items.
Turn off the furnace by either using the switch near to the furnace or by turning the temperature down with the thermostat.
Pull the handhold with force in order to open the 'door' to the filter's location.
Remove the old filter completely by pulling the filter out of its location.
Insert the new filter by sliding it into the same place where the old filter was.
Make sure that the filter is as far back as it can go.
Reattach the door by lining it up with the inside edges of the opening.
Turn back on the furnace either by flipping the switch back on or by turning the furnace on with the thermostat.
