If the YCCTEAM YCC-SW4001's vibration feature is not working as expected, then follow this guide to replace the rumble motors.
The vibration motors, otherwise known as rumble motors, are a feature of a controller that vibrates after a certain condition in a game. This condition is different in each game.
Use a Phillips screwdriver to remove the eight 9.15 mm screws that secure the rear case.
Use an opening pick to pry the back cover off of the controller.
Use a Phillips screwdriver to remove the three 9.15 mm screws from the back of the controller.
Use the tip of the opening pick to flip up the black locking flap of the ZIF connector.
Use tweezers to disconnect the white ribbon cable from the ZIF connector.
On the front side, disconnect the two vibration motor motherboard connectors.
Remove the rumble motors from the controller grips.
