If you need to replace any of the components within the YCCTEAM YCC-SW4001, you will need to remove the front cover first.
The front cover is an important part of the controller. It includes the ABXY buttons, shoulder buttons, and connects to the back cover via a ribbon cable. This component is often replaced or modified for cosmetic purposes.
Exercise caution when removing the ribbon cable, as there is a component that needs to be carefully moved and can easily be broken.
Use a Phillips screwdriver to remove the eight 9.15 mm screws that secure the rear case.
Use an opening pick to pry the back cover off of the controller.
Use a Phillips screwdriver to remove the three 9.15 mm screws from the back of the controller.
Use the tip of the opening pick to flip up the black locking flap of the ZIF connector.
Use tweezers to disconnect the white ribbon cable from the ZIF connector.
