XtremeMac Luna Dock Circuit Board Replacement
  1. XtremeMac Luna Dock Circuit Board Replacement, Bottom Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 XtremeMac Luna Dock Circuit Board Replacement, Bottom Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 XtremeMac Luna Dock Circuit Board Replacement, Bottom Panel: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the device over so that the batteries are closest to you.
    • Remove the battery lid by pressing the battery cover's tab and pulling it away from the device.
    • Push the battery against the spring and lift it out of the casing.
    • Repeat with the other battery.
  2. XtremeMac Luna Dock Circuit Board Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew all eight 12mm Phillips head screws with a Philips #1 screwdriver.
    • The iFixit 26 bit screwdriver kit will not reach the screws. Make sure to use a screwdriver that is thin enough to not get stuck in the screw holes.
  3. XtremeMac Luna Dock Circuit Board Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 XtremeMac Luna Dock Circuit Board Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the Luna back over so that the buttons are facing upward and the LCD screen is facing you.
    • Gently tilt the lid back 45 degrees so that the inside is exposed.
    • Be mindful of the wires inside of the Luna. It is easy to break a connection if a wire gets caught.
  4. XtremeMac Luna Dock Circuit Board Replacement, Dock Circuit Board: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 XtremeMac Luna Dock Circuit Board Replacement, Dock Circuit Board: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 XtremeMac Luna Dock Circuit Board Replacement, Dock Circuit Board: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the four black 7mm screws with the Phillips #1 screw driver that hold the middle circuit board to the top case.
Matt Ducasse
crwdns2935283:004/18/13crwdne2935283:0
12 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 3-47, Amido Spring 2013 crwdns2935289:0Cal Poly, Team 3-47, Amido Spring 2013crwdne2935289:0
CPSU-AMIDO-S13S3G47
crwdns2942667:0crwdne2942667:0 546
