Xiaomi Yi Motherboard Replacement
  1. Xiaomi Yi Motherboard Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xiaomi Yi Motherboard Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Push the battery door switch to the left.
    • Lift the battery door up.
  2. Xiaomi Yi Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xiaomi Yi Motherboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xiaomi Yi Motherboard Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the battery tab up.
    • Remove the battery by pulling the removal tab.
  3. Xiaomi Yi Motherboard Replacement, Front Panel: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xiaomi Yi Motherboard Replacement, Front Panel: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Introduce the plastic opening tool into any of the sides of the camera.
    • Pry with the plastic opening tool at the seam between the front and the back panel.
  4. Xiaomi Yi Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xiaomi Yi Motherboard Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xiaomi Yi Motherboard Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide prying tool along the seam until front panel is fully separated from the back panel.
  5. Xiaomi Yi Motherboard Replacement, Back Panel: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xiaomi Yi Motherboard Replacement, Back Panel: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four 3.8 mm Phillips #000 screws located in the outer corners of the motherboard.
  6. Xiaomi Yi Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xiaomi Yi Motherboard Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xiaomi Yi Motherboard Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull on and remove the black spacer located at the top inside of the camera body using the tweezers and set the part aside.
  7. Xiaomi Yi Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xiaomi Yi Motherboard Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the motherboard from from the back case by gently pulling on the lens housing.
    • Back panel remains.
  8. Xiaomi Yi Motherboard Replacement, Motherboard: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xiaomi Yi Motherboard Replacement, Motherboard: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 3.1 mm Phillips #000 screws securing the motherboard to the chassis.
    • Be sure to support the motherboard, the ribbon cable connection can easily be damaged.
  9. Xiaomi Yi Motherboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xiaomi Yi Motherboard Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xiaomi Yi Motherboard Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the rubber spacer between the image sensor and the ribbon connection for the motherboard.
    • Using the tweezers gently remove the spacer block and set aside.
  10. Xiaomi Yi Motherboard Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xiaomi Yi Motherboard Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pry gently using the flat end of the black spudger to remove the ribbon connector.
    • Lift the lens assembly up and away from the motherboard.
    • Motherboard remains.
crwdns2935229:011crwdne2935229:0
William Zipperer
crwdns2935283:009/03/15crwdne2935283:0
711 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 15-5, Blackwell Fall 2015 crwdns2935289:0USF Tampa, Team 15-5, Blackwell Fall 2015crwdne2935289:0
USFT-BLACKWELL-F15S15G5
crwdns2947412:08crwdne2947412:0
Where you buy motherboard for xiaomi yi ?
diamond1981 - crwdns2934203:0crwdne2934203:0
I wonder where I can buy this part ribbon connector to buy.
viilelaa - crwdns2934203:0crwdne2934203:0
Great guide but useless, there is no spare parts on the market for this camera
Nebojsa Rosic - crwdns2934203:0crwdne2934203:0
IC repair is always possible
AdamA -
Has someone found where to buy spare parts? Or damaged camera?
Toni - crwdns2934203:0crwdne2934203:0
Any idea where I could buy parts for this camera? Has anyone managed to find any parts on the market?
Lothar Krupka - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 12,771
