Xiaomi Yi Microphone Replacement
    1. Xiaomi Yi Microphone Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xiaomi Yi Microphone Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Push the battery door switch to the left.
      • Lift the battery door up.
    2. Xiaomi Yi Microphone Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xiaomi Yi Microphone Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xiaomi Yi Microphone Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Lift the battery tab up.
      • Remove the battery by pulling the removal tab.
    1. Xiaomi Yi Microphone Replacement, Front Panel: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xiaomi Yi Microphone Replacement, Front Panel: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Introduce the plastic opening tool into any of the sides of the camera.
      • Pry with the plastic opening tool at the seam between the front and the back panel.
    2. Xiaomi Yi Microphone Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xiaomi Yi Microphone Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xiaomi Yi Microphone Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Slide prying tool along the seam until front panel is fully separated from the back panel.
    1. Xiaomi Yi Microphone Replacement, Back Panel: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xiaomi Yi Microphone Replacement, Back Panel: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the four 3.8 mm Phillips #000 screws located in the outer corners of the motherboard.
    2. Xiaomi Yi Microphone Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xiaomi Yi Microphone Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xiaomi Yi Microphone Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Pull on and remove the black spacer located at the top inside of the camera body using the tweezers and set the part aside.
    3. Xiaomi Yi Microphone Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xiaomi Yi Microphone Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the motherboard from from the back case by gently pulling on the lens housing.
      • Back panel remains.
    1. Xiaomi Yi Microphone Replacement, Microphone: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xiaomi Yi Microphone Replacement, Microphone: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Locate the solder points connected to the red and black wire on the back of the motherboard.
    2. Xiaomi Yi Microphone Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Heat these two points with a Soldering Iron and remove the microphone. Reapply fresh solder with the replacement microphone.
      • Soldering Irons are very hot and fumes from melted solder can cause irritation. Use only in a clean, well ventilated area.
crwdns2935229:013crwdne2935229:0
Matt Bibby
crwdns2935283:008/26/15crwdne2935283:0
531 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 15-5, Blackwell Fall 2015 crwdns2935289:0USF Tampa, Team 15-5, Blackwell Fall 2015crwdne2935289:0
USFT-BLACKWELL-F15S15G5
crwdns2935297:045crwdne2935297:0
My camera came with the microphone not soldered at all (two microphone wires were hanging above the motherboard with no sign of soldering).
That was an easy repair as soon as I figured out what's the culprit, but before I've blamed the software for this issue for two days and tinkered with the software for at least 6 hours with no result.
adryjanowski, very nice tutorial, thank you!
Ivan Elizarov - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2942667:0crwdne2942667:0 8,480
