Xiaomi Redmi Note Charging Port Replacement
  1. Xiaomi Redmi Note Charging Port Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Make sure the Xiaomi Redmi Note is powered off before removing the battery.
    • Insert the plastic opening tool between the charging port and the rear case.
    • Pry the end of the rear case up from the charging port.
  2. Xiaomi Redmi Note Charging Port Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xiaomi Redmi Note Charging Port Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Run the plastic opening tool along the seam on the side of the phone to remove the rear casing.
  3. Xiaomi Redmi Note Charging Port Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xiaomi Redmi Note Charging Port Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the indentation at the bottom of the battery.
    • Place a finger in the indentation and lift up to remove the battery.
  4. Xiaomi Redmi Note Charging Port Replacement, Midframe: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xiaomi Redmi Note Charging Port Replacement, Midframe: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove twelve 3.5mm Phillips #00 screws from the midframe.
  5. Xiaomi Redmi Note Charging Port Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xiaomi Redmi Note Charging Port Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a plastic opening into the seam between the midframe and the bottom frame of the phone.
    • Run the plastic opening tool along the seam.
    • Pry up the midframe with the plastic opening tool.
    • Once the midframe has been sufficiently lifted with the tool, place a hand underneath the edge to lift the entire component out of the frame.
    • There will be snapping sounds as the clips on the midframe disconnect from the phone.
  6. Xiaomi Redmi Note Charging Port Replacement, Charging Port: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xiaomi Redmi Note Charging Port Replacement, Charging Port: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the charging port panel at the bottom of the device.
    • Remove the 2.9 mm Phillips #00 screws on the sides of the panel.
  7. Xiaomi Redmi Note Charging Port Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xiaomi Redmi Note Charging Port Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xiaomi Redmi Note Charging Port Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the antenna cable at the top right corner of the charging port.
    • Lift the antenna cable off of the panel with tweezers.
  8. Xiaomi Redmi Note Charging Port Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xiaomi Redmi Note Charging Port Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xiaomi Redmi Note Charging Port Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the panel to its back side, but do not fully lift it off of the phone yet.
    • Use a plastic opening tool to gently pry off the press fit connector attached to the back side of the panel.
  9. Xiaomi Redmi Note Charging Port Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the charging port up to remove it from the frame.
    good !!!!!!!!
    zhenzhuo999 - crwdns2934203:0crwdne2934203:0
crwdns2935229:026crwdne2935229:0
Caitlin Settles
crwdns2935283:004/26/17crwdne2935283:0
786 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S22-G4, Livingston Spring 2017 crwdns2935289:0Cal Poly, Team S22-G4, Livingston Spring 2017crwdne2935289:0
CPSU-LIVINGSTON-S17S22G4
crwdns2947412:09crwdne2947412:0
Hi, should the battery have a certain time of charge after replacement? Or just start using like everyday, charge when needed?
Luis Amaral - crwdns2934203:0crwdne2934203:0
Hi Caitlin, do you know where I can purchase an OEM Charging Port? All I can find is non OEM parts on eBay and parts on witrig. I looked into that site, and it has awful reviews, so I’m not going to try it.
ilikechocobo - crwdns2934203:0crwdne2934203:0
hi where can i buy the replacement port charger for the xioami note boo pease
View similar itemsItem - Xiaomi Mi Pad 3 Tablet PC 7.9'' MIUI 8 2.1GHz MT8176 Hexa Core 4GB+64GB WiFi
Brigitte Berkaine-Tongue - crwdns2934203:0crwdne2934203:0
How much is it to repair in Qatar riyal
Cynthia - crwdns2934203:0crwdne2934203:0
How much does it cost to repair the charging port in Qatar royals?
from Usd4 to Usd 10, I paid 8 dollars for
Yvan R -
Caitlin can you advise where replacement part could be procured online?
svedanny - crwdns2934203:0crwdne2934203:0
hi, I replaced the charge port, phone charges but the screen touch does not respond, any ideas how to fix this problem?
Yvan R - crwdns2934203:0crwdne2934203:0
After changing the same as mentioned above steps, my phone display went off.. is there any thing I missed or is there any pins releaded to display. Plz help.
Rafi Shaik - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 180
crwdns2942667:0crwdne2942667:0 39,646
