Xiaomi Redmi Note 11 Pro Dissassembly
    • First, make sure your phone is completely turned off to avoid any electrical issues.
    • Pop out the SIM card tray using a paperclip or the tool that came with your phone. This step is simple but important.
    • Gently heat the edges of the screen with a hairdryer. This softens the glue, making it easier to open.
    • Attach a suction cup to the screen to lift it slightly. Then, use a plastic prying tool to carefully work your way around the edges. Be gentle to avoid breaking anything inside.
    • Once you’ve got the screen lifted, find the battery connector and gently unplug it. This step ensures you don’t accidentally short-circuit anything.
    • For a Cracked Screen: Disconnect the old screen and remove it. Connect the new screen’s cables and fit it into place.
    • For a Battery Replacement: Remove the old battery (which might be a bit sticky) and put the new one in. Connect it properly.
    • Carefully put the phone back together. Make sure everything clicks into place and reconnect any cables you unplugged.
    • Turn your phone back on and check to see if everything’s working as it should. Test the screen and any other functions to make sure they’re functioning correctly.
    • Pop the SIM card tray back into place once you’re sure the phone is working.
    • If needed, add some adhesive around the edges of the screen or back cover to make sure everything stays in place.
Pro Tip:
If at any point you’re feeling unsure or if something seems off, it’s totally okay to take your phone to a professional. Sometimes it’s better to let the experts handle it. You can also Oxrepair it if you're from India.
Snowbot Gaming
crwdns2935283:008/15/24crwdne2935283:0
211 crwdns2915208:0crwdne2915208:0
thanks mate been looking for this
Raihan Sheikh - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 765
