Xiaomi Redmi 2 Screen Assembly Replacement
  1. Xiaomi Redmi 2 Screen Assembly Replacement, Motherboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xiaomi Redmi 2 Screen Assembly Replacement, Motherboard: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of the spudger to remove the back panel from the mid-frame and front body.
  2. Xiaomi Redmi 2 Screen Assembly Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert your finger into the curved opening of the mid-frame.
    • Lift the battery and remove.
  3. Xiaomi Redmi 2 Screen Assembly Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the SIM and/or memory cards if present.
    • Remove twelve 3.4 mm Phillips #000 screws securing the mid-frame to the front body.
  4. Xiaomi Redmi 2 Screen Assembly Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the spudger between the mid-frame and front body, gradually prying the two bodies apart as you slide the spudger around the perimeter of the phone.
  5. Xiaomi Redmi 2 Screen Assembly Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 3.4 mm Phillips #000 screw that holds the motherboard to the front body.
    • Keep this screw separate from the initial twelve.
  6. Xiaomi Redmi 2 Screen Assembly Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xiaomi Redmi 2 Screen Assembly Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using one prong of the tweezers, pry back the brown clip located on top of the LCD ribbon connector.
  7. Xiaomi Redmi 2 Screen Assembly Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xiaomi Redmi 2 Screen Assembly Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using one prong of the tweezers, pry the ribbon clip away from the motherboard.
  8. Xiaomi Redmi 2 Screen Assembly Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xiaomi Redmi 2 Screen Assembly Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift and hinge the motherboard with your fingers.
  9. Xiaomi Redmi 2 Screen Assembly Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xiaomi Redmi 2 Screen Assembly Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using one prong of the tweezers, lift and pry back the metal clip positioned over the front proximity sensor ribbon connector.
  10. Xiaomi Redmi 2 Screen Assembly Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xiaomi Redmi 2 Screen Assembly Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the tweezers, pull the antenna connector from the motherboard.
  11. Xiaomi Redmi 2 Screen Assembly Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the motherboard out of the front cover and set aside.
  12. Xiaomi Redmi 2 Screen Assembly Replacement, Front Speaker: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the nylon or metal spudger, gently pry the front speaker from the screen assembly.
  13. Xiaomi Redmi 2 Screen Assembly Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using your fingers, gently lift the front speaker from the screen assembly.
  14. Xiaomi Redmi 2 Screen Assembly Replacement, PCB Circuit Board: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 2.9 mm Phillips #000 screw that holds the PCB circuit board to the screen assembly.
  15. Xiaomi Redmi 2 Screen Assembly Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the tweezers, lift the antenna connector from the PCB circuit board.
  16. Xiaomi Redmi 2 Screen Assembly Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xiaomi Redmi 2 Screen Assembly Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Do not remove the PCB circuit board at this time.
    • Using the nylon or metal spudger, gently pry back the top of the PCB circuit board from the screen assembly.
  17. Xiaomi Redmi 2 Screen Assembly Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the nylon or metal spudger, pry back the silver clip covering the ribbon connector.
  18. Xiaomi Redmi 2 Screen Assembly Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xiaomi Redmi 2 Screen Assembly Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully lift the PCB circuit board from the screen assembly and set aside.
    • The screen assembly is pictured to the left of the circuit board and is now ready for repair or replacement.
crwdns2935229:031crwdne2935229:0
Alicia Brenner
crwdns2935283:010/01/15crwdne2935283:0
3.569 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 1-3, Leahy Fall 2015 crwdns2935289:0USF Tampa, Team 1-3, Leahy Fall 2015crwdne2935289:0
USFT-LEAHY-F15S1G3
ok so good is can service nice
SAFUTRA - crwdns2934203:0crwdne2934203:0
Touch is not working after replacing full LCD, Brought new display & changed again but no luck, Display is okay but touch not working.
Rajesh Gopisetti - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 17,630
