Xiaomi Redmi 2 Motherboard Replacement
crwdns2942287:0crwdne2942287:0Use this guide to remove the motherboard in your Xiaomi Redmi 2 for repair or replacement.
crwdns2944105:0crwdne2944105:0
Use the flat end of the spudger to remove the back panel from the mid-frame and front body.
Insert your finger into the curved opening of the mid-frame.
Lift the battery and remove.
Remove twelve 3.4 mm Phillips #000 screws securing the mid-frame to the front body.
Slide the spudger between the mid-frame and front body, gradually prying the two bodies apart as you slide the spudger around the perimeter of the phone.
Remove the 3.4 mm Phillips #000 screw that holds the motherboard to the front body.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Using one prong of the tweezers, pry back the brown clip located on top of the LCD ribbon connector.
Using one prong of the tweezers, pry the ribbon clip away from the motherboard.
I broke the connector of this flat cable, which with a replacement part without having to change the entire mother board? Another doubt, this flat cable is responsible for which function in the cell?
pull up the black plastic part of this conector to free the ribbon before remove! this step is missing!!!!
Thanks Rodrigo, saved me!
Rodrigo -
Lift and hinge the motherboard with your fingers.
Using one prong of the tweezers, lift and pry back the metal clip positioned over the front proximity sensor ribbon connector.
Using the tweezers, pull the antenna connector from the motherboard.
Lift the motherboard out of the front cover and set aside.
crwdns2935229:047crwdne2935229:0
crwdns2947412:017crwdne2947412:0
this is very helpful
hi brother mi phone was water damaged .it was not wrking i mean phone gets on but no display. phone gets ring and i can lift call and speak. when i connect to laptop i can access files in it. its get charging on connecting to charger
can u suggest me wat to do
please
may be LCD is damage. can fix it at 82877181 contact Peter for checking.
netman91 -
Hi bro I'm having redmi 2 mobile and it has a problem it is not taking any os it's having a compliant of not receiving os .....
There is any solution for that
Please give me reply bro any suggestions
Can i know the name of the motherboard used for redmi 2 prime 16GB,please tell me the name bro
how and where to buy motherboard for redmi2
i want new mothe board redmi
i want redmi 2 prime mother board
How to buy redmi prime 2 mother bord
hey my Redmi 2 is not working, what can I do? it started to make turn off it self time by time and after it turn off completly, if I make to turn it it on not working, it makes vibration only without turn on, what can I do?? please help me because am just seeking a help
Sir, my phone (Redmi 2 prime) doesn't starts. One day it got off on 0% charge. I put it on charge but from the next day it was not opening. What to do?
My phones mother bord is damaged I needed it
My phone is mother board damage I need it
Hello, i want ask for u, my handpone redmi 2 lte can’t on..why? What is problem?
Great! This phone is very easy to disassembly!
السلام عليكم
لدي جوال شاومي s2
منفذالشاحن خربان
That's unnecessary. The cover itself has a small notch on it to remove it to the left
Mad Max - crwdns2934203:0crwdne2934203:0
