Xiaomi Redmi 2 Front Speaker Replacement
  1. Xiaomi Redmi 2 Front Speaker Replacement, Motherboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xiaomi Redmi 2 Front Speaker Replacement, Motherboard: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of the spudger to remove the back panel from the mid-frame and front body.
    That's unnecessary. The cover itself has a small notch on it to remove it to the left
    Mad Max - crwdns2934203:0crwdne2934203:0
  2. Xiaomi Redmi 2 Front Speaker Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert your finger into the curved opening of the mid-frame.
    • Lift the battery and remove.
  3. Xiaomi Redmi 2 Front Speaker Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the SIM and/or memory cards if present.
    • Remove twelve 3.4 mm Phillips #000 screws securing the mid-frame to the front body.
  4. Xiaomi Redmi 2 Front Speaker Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the spudger between the mid-frame and front body, gradually prying the two bodies apart as you slide the spudger around the perimeter of the phone.
  5. Xiaomi Redmi 2 Front Speaker Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 3.4 mm Phillips #000 screw that holds the motherboard to the front body.
    • Keep this screw separate from the initial twelve.
  6. Xiaomi Redmi 2 Front Speaker Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xiaomi Redmi 2 Front Speaker Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using one prong of the tweezers, pry back the brown clip located on top of the LCD ribbon connector.
  7. Xiaomi Redmi 2 Front Speaker Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xiaomi Redmi 2 Front Speaker Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using one prong of the tweezers, pry the ribbon clip away from the motherboard.
    I broke the connector of this flat cable, which with a replacement part without having to change the entire mother board? Another doubt, this flat cable is responsible for which function in the cell?
    lucaslgf2 - crwdns2934203:0crwdne2934203:0
    pull up the black plastic part of this conector to free the ribbon before remove! this step is missing!!!!
    Rodrigo Cunha - crwdns2934203:0crwdne2934203:0
    Thanks Rodrigo, saved me!
    Rodrigo -
  8. Xiaomi Redmi 2 Front Speaker Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xiaomi Redmi 2 Front Speaker Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift and hinge the motherboard with your fingers.
  9. Xiaomi Redmi 2 Front Speaker Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xiaomi Redmi 2 Front Speaker Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using one prong of the tweezers, lift and pry back the metal clip positioned over the front proximity sensor ribbon connector.
  10. Xiaomi Redmi 2 Front Speaker Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xiaomi Redmi 2 Front Speaker Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the tweezers, pull the antenna connector from the motherboard.
  11. Xiaomi Redmi 2 Front Speaker Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the motherboard out of the front cover and set aside.
  12. Xiaomi Redmi 2 Front Speaker Replacement, Front Speaker: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the nylon or metal spudger, gently pry the front speaker from the screen assembly.
  13. Xiaomi Redmi 2 Front Speaker Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using your fingers, gently lift the front speaker from the screen assembly.
    Thanks. I was replacing a friend's digitizer, and in the process, broke the speaker (they come apart very easily). So I decided to replace her broken speaker with mine (we both have a Note 2). Then I broke MINE taking it out. So now I have to order two new speakers. Arggghhh.
    moshiach.now - crwdns2934203:0crwdne2934203:0
    Sar rademi 2 front Speakers probably
    Amol Surve - crwdns2934203:0crwdne2934203:0
Alicia Brenner
crwdns2935283:010/01/15crwdne2935283:0
3.569 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 1-3, Leahy Fall 2015 crwdns2935289:0USF Tampa, Team 1-3, Leahy Fall 2015crwdne2935289:0
USFT-LEAHY-F15S1G3
How can I remove the contact from the speaker? I bought a new screen and it hasn't this contact and the vibracall module, but the second I know how to remove from the old screen.
brunofichos - crwdns2934203:0crwdne2934203:0
sorry about my english, I want to say "back speaker's contact" not "contact from the speaker". Thanks
brunofichos -
You know how to remove the speaker contacts from the rear speaker. It's stuck in the redmi2pro frame. I bought an LCD touch frame and need to move the components to the new one.
afreitasleonardo - crwdns2934203:0crwdne2934203:0
Rademi 2 front Speakers problem
crwdns2936753:030crwdne2936753:0 33
crwdns2942667:0crwdne2942667:0 7,228
