In this guide I will show you how to replace the right wheel.
This will help you if the vacuum cleaner only runs in circles or reports error 7 or error 8. Please note, however, that these errors can also have other causes.
Turn off the device by pressing and holding the power button.
Open the cover upwards.
Lift the dustbin upward to remove it.
Remove the main brush holder by pressing both locks inward and lifting it up.
Remove the main brush.
Remove the screw holding the side brush.
Remove the side brush along with the screw by lifting it upward.
Lift the front wheel with the screwdriver.
Completely pull the front wheel upward to remove it.
Remove the seven screws holding the bottom panel.
Lift the bottom cover up.
Remove the three screws from the motor
Pull the motor out upwards (plug connection with the circuit board)
Remove the three screws from the drive unit
Remove the wheel upwards (connected to the circuit board via a plug connection)
Work through the steps in reverse order to reassemble your device.
crwdns2934873:0crwdne2934873:0
100%
            crwdns2934883:0oldturkey03crwdne2934883:0      crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
