Use this guide to remove the headphone jack from your Xiaomi Mi Pad.
Remove the micro SD card slot from the left side of the device using either the metal pin included with the device or a SIM card eject tool.
Use a plastic opening tool and/or opening pick to gently pry the back panel away from the device. Work your way around the device, slowly increasing the gap.
Remove the twelve 3.0 mm Phillips #000 screws on the upper cover of the device.
Remove the upper cover from the device.
Use a plastic opening tool to pull up and remove the headphone jack from the upper cover.
