Xiaomi Mi Pad Battery Replacement
  1. Xiaomi Mi Pad Battery Replacement, Rear Case Assembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the micro SD card slot from the left side of the device using either the metal pin included with the device or a SIM card eject tool.
  2. Xiaomi Mi Pad Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xiaomi Mi Pad Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a plastic opening tool and/or opening pick to gently pry the back panel away from the device. Work your way around the device, slowly increasing the gap.
    • The back panel has small clips and light adhesive that easily releases from the device.
  3. Xiaomi Mi Pad Battery Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xiaomi Mi Pad Battery Replacement, Battery: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the twelve 3.0 mm Phillips #000 screws on the upper cover of the device.
  4. Xiaomi Mi Pad Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the upper cover from the device.
  5. Xiaomi Mi Pad Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xiaomi Mi Pad Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a plastic opening tool to disconnect the three ribbon cable connectors.
    • If you're only going to replace the battery, you should only need to disconnect the smallest ribbon cable that connects the battery to the motherboard.
  6. Xiaomi Mi Pad Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully pry around the perimeter of the battery with a plastic opening tool to loosen the adhesive securing the battery to the device.
    • Be gentle when removing the battery, as lithium-ion batteries should not be bent or punctured.
  7. Xiaomi Mi Pad Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xiaomi Mi Pad Battery Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xiaomi Mi Pad Battery Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • If you disconnected all three connectors, the charging port ribbon cable may have a small amount of adhesive securing it to the battery. Gently pry the cable free of the battery and lift the battery up and out of the device.
crwdns2935229:019crwdne2935229:0
Jessica
crwdns2935283:009/03/15crwdne2935283:0
731 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 12-5, Blackwell Fall 2015 crwdns2935289:0USF Tampa, Team 12-5, Blackwell Fall 2015crwdne2935289:0
USFT-BLACKWELL-F15S12G5
crwdns2947412:012crwdne2947412:0
Hi
Great Tutorial, but where can i buy a replacement Battery?
THANKS
Marcel - crwdns2934203:0crwdne2934203:0
Go to Leamington road and you will get it
affan -
Go to Leamington road mumbai
affan -
Where to purchase the Mi Paf battery?
Dino Bay - crwdns2934203:0crwdne2934203:0
Please please make a video for it. I need it desperately.
Man Mohan Shukla - crwdns2934203:0crwdne2934203:0
It is not so easy when u have a deal with factory battery. I think guide tell us about replace battery not first time ;)
tsyba1980 - crwdns2934203:0crwdne2934203:0
Can somebody tell about replacement charge jack on this device?
Where can I get brand new mi tablet battery in india?
Saurabh saindane - crwdns2934203:0crwdne2934203:0
Step 3: got 2 screws cover with orange Mi sticker. Don’t forget to unscrew them.
Step 6: got tape stick behind the battery, very sticky. Need remove gently and slowly.
Other work very well, thanks for the tutorial. Successfully replace my Mi Pad battery.
Andy Teoh - crwdns2934203:0crwdne2934203:0
What sort is brand for light adhesive (glue)?
Vitaly Titov - crwdns2934203:0crwdne2934203:0
Need the female connector for battery. This soldered to board.
By accident was destroyed and want to change it…
How know the part number ? and can help.
Dino
Dino Solomon - crwdns2934203:0crwdne2934203:0
My mipad not starting after battery replacement. Red light blinks 2 times and shows MI logo then turn off… but boots perfect with old battery. How do i resolve this issue?
brahmasoor anirudhan - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 15
crwdns2936753:07crwdne2936753:0 90
crwdns2936753:030crwdne2936753:0 248
crwdns2942667:0crwdne2942667:0 25,628
