Use this guide to replace a worn-out or dead battery in your Xiaomi Mi 8.
If your battery is swollen, take appropriate precautions. For your safety, discharge your battery below 25% before disassembling your phone. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair.
You’ll need replacement adhesive to reattach components when reassembling the device.
Apply a heated iOpener to the rear glass to loosen the adhesive beneath the edges. Apply the iOpener for at least two minutes.
Secure a suction handle to the lower edge of the rear glass, as close to the edge as possible.
Lift the rear glass with the suction handle to create a gap between the glass and the frame.
Insert an opening pick into the gap.
Slide the opening pick to the bottom right corner of the phone.
Insert a second opening pick and slide it to the bottom left corner to cut the adhesive.
Leave the opening picks in place to prevent the adhesive from resealing.
Insert a third opening pick at the bottom left corner.
Start to slide the opening pick from the bottom left corner along the side of the Xiaomi Mi 8 to cut the adhesive.
As the adhesive cools down it gets harder to cut. If necessary use your iOpener to reheat it.
Leave the opening pick in the top left corner to prevent the adhesive from resealing.
The back cover of MI 8 easily breaks while sliding the opening pick because it is made of fragile glass. Before sliding the pick, rim of the back cover should be heated enough to make adhesive loose.
Insert a fourth opening pick under the top left corner of the rear glass.
Slide the opening pick along the top to cut the adhesive.
Leave the opening pick in the top right corner to prevent the adhesive from resealing.
Insert a fifth opening pick at the top right corner of the phone.
Slide the opening pick along the right edge to cut the remaining adhesive.
Carefully lift the rear glass and fold it to the left side to access the fingerprint flex connector.
Use a spudger to pry up and disconnect the fingerprint flex cable.
Remove the rear glass.
Remove the ten screws that secure the motherboard cover.
Eight Phillips #00 screws (3.4 mm length)
Two Phillips #00 screws (3.5 mm length)
Bei dem MI 8 ist (auf dem Bild gesehen) unten links noch eine Schraube (3,4 mm #00 Kreuzschlitzschraube) die zum Entfernen des Motherboards gelöst werden muß
Hallo Jürgen, danke für den Hinweis. Die Schraube wurde übersehen und ich habe den Schritt entsprechend angepasst.
Slide an opening pick under the right side of the motherboard cover.
Twist the opening pick sideways to pry up and slightly lift the motherboard cover.
Carefully remove the motherboard cover including the NFC antenna.
Use a spudger to pry up and disconnect the battery flex cable located at the bottom of the motherboard.
Use a pair of tweezers to peel the black ends of the adhesive tabs off the battery.
Pull out the first adhesive tab from underneath the battery.
crwdns2935267:0crwdne2935267:0Plastic Cards$2.99
Use a pair of tweezers to pull out the second adhesive tab from underneath the battery.
Use an opening pick or plastic card to pry the battery out of its recess until you can get a good grip.
If possible, turn on your phone and test your repair before installing new adhesive and resealing the phone.
Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the phone at the places where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
For optimal performance, calibrate your newly installed battery: Charge it to 100%, and keep charging it for at least two more hours. Then, use it until it shuts off due to low battery. Finally, charge it uninterrupted to 100%
crwdns2935229:021crwdne2935229:0
crwdns2944067:011crwdne2944067:0
Thanks ! Its helps me alot
excellent, thanks
Echt Klasse, allerdings sind es 8 schwarze schrauben bei der Mainboard Abdeckung. Ansonsten echt top Anleitung, vielen Dank
Die deutsche Übersetzung war veraltet, ich habe sie aktualisiert. Danke! Viel Spaß mit deinem Xiaomi.
Danke für die Anleitung erstmal. Ich habe jedoch die Keramik Version des Mi8 und bei mir scheitert es bereits beim Anheben der Rückabdeckung. Diese gibt quasi überhaupt nicht nach und ich bekommen kein Spektrum dazwischen. Irgendwelche Tipps?
Hej Gregor, vielleicht ist das Keramik nicht ganz so leitfähig wie das Glas. Dann müsstest du die Rückseite ein wenig länger erwärmen, um den Kleber aufzuweichen.
Das Problem hatte ich auch anfangs. Mit dem Messer bin ich dann letztendlich doch rein gekommen und habe einen ausreichend großen Spalt geschaffen um mit den Plektren wie gezeigt fortzufahren.
Thanks for the tutorial! Which adhesive tape would be the most suitable? 2mm?
This review doesn't mention anything about where to get the adhesive from (should be in parts!), I bought the battery and it doesn't include the adhesive.
Aside from that you will need to change the glue on the rear part of your phone, again it's not mentioned!
Wo soll man den neuen Kleber herbekommen?
Ersatzklebestreifen bekommst du bei iFixit im Store.
