Xiaomi Mi 4 Motherboard Replacement
  1. Xiaomi Mi 4 Motherboard Replacement, Rear Case/Midframe: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xiaomi Mi 4 Motherboard Replacement, Rear Case/Midframe: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xiaomi Mi 4 Motherboard Replacement, Rear Case/Midframe: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Check to make sure that the device is powered off.
    • Use a pin or paper clip to insert in the hole on the side of the phone next to the micro SIM cardholder to remove the tray.
    • Remove the SIM card tray from the Xiaomi Mi 4 and store it somewhere safe.
  2. Xiaomi Mi 4 Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xiaomi Mi 4 Motherboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xiaomi Mi 4 Motherboard Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Metal Spudger
    $2.99
    • Using the flat metal spudger and curved metal spudger, make a wedge between the plastic back cover and the inner frame
    • Using the second spudger, slowly work your way around the perimeter of the device
    • Listen for clicking sounds as you are prying the back cover away from the frame
    • As the back cover is almost completely removed, use the suction-cup tool to remove the plastic cover without damaging the back
  3. Xiaomi Mi 4 Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xiaomi Mi 4 Motherboard Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xiaomi Mi 4 Motherboard Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a 000 phillips head screwdriver to remove the 10 1.2mm phillips head screws in the plastic frame that hold the motherboard and battery.
    • Use a 000 phillips head screwdriver to remove the 3 0.5mm phillips head screws in the plastic frame that hold the motherboard and battery.
    • Use the small plastic opening tool and place it in the slot on the bottom right corner of the inner frame and carefully pry it off.
  4. Xiaomi Mi 4 Motherboard Replacement, Battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xiaomi Mi 4 Motherboard Replacement, Battery: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xiaomi Mi 4 Motherboard Replacement, Battery: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use tweezers to gently disconnect the connections that run across the battery and are connected to the motherboard.
    • Proceed to gently remove the tape like connector from the battery until it is completely off.
    • Use tweezer to disconnect battery’s wire from the motherboard.
  5. Xiaomi Mi 4 Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xiaomi Mi 4 Motherboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the plastic opening tool to gently pry the battery out of its casing for removal.
  6. Xiaomi Mi 4 Motherboard Replacement, Motherboard: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With the battery removed locate the left-hand cable connected to the motherboard. With the tweezers, firmly grasp the wires of the connector and gently disconnect the cable from the motherboard.
    • Find the other cable connecting the motherboard to the device at the top right-hand side of the phone, and carefully use the tweezers to remove that as well.
  7. Xiaomi Mi 4 Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xiaomi Mi 4 Motherboard Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Wedge the plastic opening tool, between the motherboard and the inner region of the phone in the slot atop the motherboard.
crwdns2935229:028crwdne2935229:0
William Pendeergraft
crwdns2935283:009/08/15crwdne2935283:0
2 459 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 15-6, Blackwell Fall 2015 crwdns2935289:0USF Tampa, Team 15-6, Blackwell Fall 2015crwdne2935289:0
USFT-BLACKWELL-F15S15G6
crwdns2935297:011crwdne2935297:0
crwdns2947412:09crwdne2947412:0
Ruined my motherboard to Xiaomi mi4c, do you know where can I buy?
Milos Milos - crwdns2934203:0crwdne2934203:0
I have broken one of the cable connections on the motherboard ( top one in Step 6). Do you know where I can buy a new motherboard?
Ben Dungey - crwdns2934203:0crwdne2934203:0
you can buy the motherboard on taobao.com
Dong Zhengyue -
sim card reader is damaged. Do I need to have whole motherboard replaced
Shravan - crwdns2934203:0crwdne2934203:0
sir i need MI4I motherboard unable to find elsewhere
Mobile # 09060907775
Thalanki Balaji - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 19
crwdns2936753:030crwdne2936753:0 56
crwdns2942667:0crwdne2942667:0 37,615
