Xiaomi Air Pump Battery Replacement
  1. Xiaomi Air Pump Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • First, is that using ordinary flux for battery soldering will take you forever and the silver plating will not even stick to the lead. You need to get a battery / steel flux that heats up hella fast and will stick the lead instantly to the plating and battery end.
  2. Xiaomi Air Pump Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Second, make sure to flatten your solder sites. I wasn't able to flatten mine so much that I ended up having a hard time returning the batteries to their original place, which made it impossible to assemble back everything into the casing. .
    • I didn't want to redo my solder as the plating I had left was quite thin and so I'll just wait till I need to replace the batteries again with new plating ready to replace as well. That is if the pump piston doesn't give up on me before then.
    • Third, nobody at the utube academy said this, but I do actually recommend lightly lubing (emphasis on light) the gears and inside the piston for some maintenance and to help prolong the life of the pump. It doesn't hurt.
Turtz
crwdns2935283:005/26/18crwdne2935283:0
169 crwdns2915208:0crwdne2915208:0
crwdns2936751:024crwdne2936751:0 12
crwdns2936753:07crwdne2936753:0 105
crwdns2936753:030crwdne2936753:0 519
crwdns2942667:0crwdne2942667:0 5,695
