Xiaomi Air 12 Screen Replacement
    • Remove the screws on the back. 1 of them is under the rubber pads in the center
    • Remove the back gently. Screen replacement stick can help. There are several plastic holding it.
    • Remove the connectors going to the screen. 2 wifi cables near the battery. One camera cable halfway to the carger. One screen cable on at the HDMI.
    • Remove the screws holding the hinges on the corners. 4 screws holding them.
    • Turn the hinges upwards till 90 degrees.
    • Remove the screen from the main board.
    • Remove 2 screws from the bottom.
    • pull the screen towards the place of the screws and it will come out.
    • Remove the screen. Remove the connector cable.
    • Check if the cable was wrong not the whole screen.
    • Do everything backwards.
    • Connect the cable.
    • Push the new screen away from the places of the screws.
    • Add the screws.
    • Put back the whole together. Turn the hinges back.
    • Add the screws to the holes marked with a triangle.
    • Reconnect the cables to the main board.
    • Put back the lid of the main board.
Robin Csutorás
crwdns2935283:004/09/19crwdne2935283:0
133 crwdns2915208:0crwdne2915208:0
crwdns2936753:030crwdne2936753:0 59
crwdns2942667:0crwdne2942667:0 636
