Xiaomi Air 12 SSD Replacement
  1. Xiaomi Air 12 SSD Replacement, Rear Casing: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Orient the computer so the Xiaomi logo is at the bottom of the device.
    Hello,
    I have a problem on my Mi air 12 , specifically with the lcd cable port on the mother board. I want to replace it but i can’t seem to find where to buy the parts.
    Pleas help me
    Kind regards
    L.
    lanusjeleus - crwdns2934203:0crwdne2934203:0
  2. Xiaomi Air 12 SSD Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xiaomi Air 12 SSD Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xiaomi Air 12 SSD Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the plastic opening tool underneath the top-middle rubber covering and lift upwards to reveal the hidden screw.
  3. Xiaomi Air 12 SSD Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xiaomi Air 12 SSD Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the eight 3 mm screws using the Torx T5 driver by inserting the screwdriver into each screw and rotating counterclockwise.
  4. Xiaomi Air 12 SSD Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xiaomi Air 12 SSD Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xiaomi Air 12 SSD Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the plastic opening tool into each side of the computer and push the tool downwards to pop open the back cover.
    • You will hear popping noises as you remove the cover.
  5. Xiaomi Air 12 SSD Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xiaomi Air 12 SSD Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the back of the laptop by gently lifting the casing upwards.
  6. Xiaomi Air 12 SSD Replacement, SSD: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xiaomi Air 12 SSD Replacement, SSD: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Detach the white and black speaker wires by pulling them from the small black tabs along the perimeter of the metal bracket.
    Would be nice if I found somewhere a replacement for the Mainboard….no luck so far and Xiaomi does not sell.
    Mk k - crwdns2934203:0crwdne2934203:0
  7. Xiaomi Air 12 SSD Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xiaomi Air 12 SSD Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 1.5mm screw using the JIS #00 screwdriver.
  8. Xiaomi Air 12 SSD Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xiaomi Air 12 SSD Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the SSD up from the device and gently pull the SSD from the laptop.
Hannah Kwan
crwdns2935283:004/18/18crwdne2935283:0
884 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S18-G4, Livingston Spring 2018 crwdns2935289:0Cal Poly, Team S18-G4, Livingston Spring 2018crwdne2935289:0
CPSU-LIVINGSTON-S18S18G4
crwdns2935297:034crwdne2935297:0
crwdns2936753:07crwdne2936753:0 32
crwdns2936753:030crwdne2936753:0 121
crwdns2942667:0crwdne2942667:0 6,038
