Use this guide to replace the SSD in your Xiaomi Air 12.
Orient the computer so the Xiaomi logo is at the bottom of the device.
Insert the plastic opening tool underneath the top-middle rubber covering and lift upwards to reveal the hidden screw.
Remove the eight 3 mm screws using the Torx T5 driver by inserting the screwdriver into each screw and rotating counterclockwise.
Insert the plastic opening tool into each side of the computer and push the tool downwards to pop open the back cover.
Remove the back of the laptop by gently lifting the casing upwards.
Detach the white and black speaker wires by pulling them from the small black tabs along the perimeter of the metal bracket.
Remove the 1.5mm screw using the JIS #00 screwdriver.
Lift the SSD up from the device and gently pull the SSD from the laptop.
