Xiaomi Air 12 Motherboard Replacement
  1. Xiaomi Air 12 Motherboard Replacement, Rear Casing: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Orient the computer so the Xiaomi logo is at the bottom of the device.
  2. Xiaomi Air 12 Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xiaomi Air 12 Motherboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xiaomi Air 12 Motherboard Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the plastic opening tool underneath the top-middle rubber covering and lift upwards to reveal the hidden screw.
  3. Xiaomi Air 12 Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xiaomi Air 12 Motherboard Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the eight 3 mm screws using the Torx T5 driver by inserting the screwdriver into each screw and rotating counterclockwise.
  4. Xiaomi Air 12 Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xiaomi Air 12 Motherboard Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xiaomi Air 12 Motherboard Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the plastic opening tool into each side of the computer and push the tool downwards to pop open the back cover.
    • You will hear popping noises as you remove the cover.
  5. Xiaomi Air 12 Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xiaomi Air 12 Motherboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the back of the laptop by gently lifting the casing upwards.
  6. Xiaomi Air 12 Motherboard Replacement, SSD: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xiaomi Air 12 Motherboard Replacement, SSD: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Detach the white and black speaker wires by pulling them from the small black tabs along the perimeter of the metal bracket.
  7. Xiaomi Air 12 Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xiaomi Air 12 Motherboard Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 1.5mm screw using the JIS #00 screwdriver.
  8. Xiaomi Air 12 Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xiaomi Air 12 Motherboard Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the SSD up from the device and gently pull the SSD from the laptop.
  9. Xiaomi Air 12 Motherboard Replacement, Battery: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Detach the red wire from the tabs on the perimeter of the metal bracket.
  10. Xiaomi Air 12 Motherboard Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xiaomi Air 12 Motherboard Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xiaomi Air 12 Motherboard Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a PH1 screwdriver to remove the five 2mm black screws.
    • Remove two silver 1mm JIS #00 screws.
    • There will be clear plastic spacers that come off with the silver screws.
  11. Xiaomi Air 12 Motherboard Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xiaomi Air 12 Motherboard Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xiaomi Air 12 Motherboard Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the battery up and pull out from the device.
    • The metal bracket will come out with the battery.
  12. Xiaomi Air 12 Motherboard Replacement, Motherboard: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xiaomi Air 12 Motherboard Replacement, Motherboard: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the silver connection cover next to the USB ports using the plastic opening tool and your hands.
  13. Xiaomi Air 12 Motherboard Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xiaomi Air 12 Motherboard Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xiaomi Air 12 Motherboard Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the four ribbon cables by lifting the connector up with the plastic opening tool and pulling the ribbon cable out.
  14. Xiaomi Air 12 Motherboard Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xiaomi Air 12 Motherboard Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xiaomi Air 12 Motherboard Replacement: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the gray and black wire connectors using the plastic opening tool to lift them up.
  15. Xiaomi Air 12 Motherboard Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xiaomi Air 12 Motherboard Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the webcam connector by gently pulling the cable out by hand.
  16. Xiaomi Air 12 Motherboard Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xiaomi Air 12 Motherboard Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the video cable on the connector using the plastic opening tool to disconnect it.
  17. Xiaomi Air 12 Motherboard Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xiaomi Air 12 Motherboard Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the seven black 2mm screws using a PH1 screwdriver.
  18. Xiaomi Air 12 Motherboard Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xiaomi Air 12 Motherboard Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xiaomi Air 12 Motherboard Replacement: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently lift the motherboard out by hand.
crwdns2935229:05crwdne2935229:0
Hannah Kwan
crwdns2935283:004/18/18crwdne2935283:0
899 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S18-G4, Livingston Spring 2018 crwdns2935289:0Cal Poly, Team S18-G4, Livingston Spring 2018crwdne2935289:0
CPSU-LIVINGSTON-S18S18G4
crwdns2935297:034crwdne2935297:0
crwdns2947412:011crwdne2947412:0
Where do you order a replacement?
I couldn’t find any parts for my Xiaomi air 12.
Jon Jag - crwdns2934203:0crwdne2934203:0
di you get it?
zelenmix -
Same here. Where to get motherboard to xiaomi mi 12?
imthespace - crwdns2934203:0crwdne2934203:0
Did yoiu get it?
zelenmix -
... I would like to replace but I can't find a motherboard anywhere ... can anyone help me, where to buy the board for best price?
Aljoša Jelen - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 31
crwdns2936753:030crwdne2936753:0 137
crwdns2942667:0crwdne2942667:0 6,056
