Use this guide to replace the battery in your Xiaomi Air 12.
Orient the computer so the Xiaomi logo is at the bottom of the device.
Insert the plastic opening tool underneath the top-middle rubber covering and lift upwards to reveal the hidden screw.
Remove the eight 3 mm screws using the Torx T5 driver by inserting the screwdriver into each screw and rotating counterclockwise.
Insert the plastic opening tool into each side of the computer and push the tool downwards to pop open the back cover.
Remove the back of the laptop by gently lifting the casing upwards.
Detach the white and black speaker wires by pulling them from the small black tabs along the perimeter of the metal bracket.
Would be nice if I found somewhere a replacement for the Mainboard….no luck so far and Xiaomi does not sell.
Remove the 1.5mm screw using the JIS #00 screwdriver.
Lift the SSD up from the device and gently pull the SSD from the laptop.
Detach the red wire from the tabs on the perimeter of the metal bracket.
Use a PH1 screwdriver to remove the five 2mm black screws.
Remove two silver 1mm JIS #00 screws.
Lift the battery up and pull out from the device.
crwdns2935229:011crwdne2935229:0
I have a problem, the battery do not really charge, 100% is reach in few minutes, and it works less than 15 minutes on battery. Is anybody have a solution ? Bios update maybe ?
I got to pull out my bloated battery…. Though it could work with just the charger on stand by but it did not… Anyone knows where I can purchase new battery? Can't bring it to the shop because of quarantine but need to work from home.
I removed the bloated battery too. It can’t power on properly. The power light just just on and off around every 5 seconds. Is yours the same?
sdot -
after I change the battery it always says plugged in not charge, anyone has the same issue?
Hi. There is no page for keyboard replacement so I'm asking my question here: how can I find a keyboard replacement for my mi 12.5 notebook? Only two buttons do not work.
Hi! your tutorial is really great! Helped a lot. Thanks for posting this!
Some hint that may be helpful for others: I bought a replacement battery from company KingSener at Aliexpress. At first it seems to fit very well, but after remounting everything I found out that the clickpad doesn't work correctly. It just doesn't click anymore because the replacement battery is somehow thicker and hinders the clickpad. I then opened it again and saw that in the replacement the two middle cells are somehow smaller than in the original battery. The empty space is filled with a pad of flexible foam that is even thicker than the cells. I removed part of it with a knife (be sure to not damage the cells!) and assembled again. Now the clickpad is working as expected (or at least very close to, I am not totally sure).
Jürgen
Hello,
I have a problem on my Mi air 12 , specifically with the lcd cable port on the mother board. I want to replace it but i can’t seem to find where to buy the parts.
Pleas help me
Kind regards
L.
lanusjeleus - crwdns2934203:0crwdne2934203:0
