This guide provides instructions on how to replace the front-facing camera on a Xelio P900A-BK.
Remove the two 5.4mm bottom screws.
Set aside.
Insert a plastic opening tool between the screen and the rear case and carefully pry the tablet open.
Gently work your way around the entire tablet and do not force the case open prematurely.
Remove the connection between the camera and the motherboard.
Open the black ribbon holder then remove the ribbon from its connection.
Remove the tape covering the front facing camera entirely to expose one of the motherboard screws.
Use the smaller plastic opening tool to remove the camera from its socket.
