Xbox Series (Model 1914) Trimmer Potentiometer Sensor Replacement
  1. Xbox Series (Model 1914) Trimmer Potentiometer Sensor Replacement, Xbox Series (Model 1914) Trimmer Potentiometer Sensor: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xbox Series (Model 1914) Trimmer Potentiometer Sensor Replacement, Xbox Series (Model 1914) Trimmer Potentiometer Sensor: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xbox Series (Model 1914) Trimmer Potentiometer Sensor Replacement, Xbox Series (Model 1914) Trimmer Potentiometer Sensor: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Before you begin, remove the two double-A (AA) batteries from the back of the controller.
    • Grip the controller firmly once you have wedged the spudger into the seam of the back and side panels.
    • Pry the side panel away from the back panel by moving the spudger back and forth. Do this motion all the way around the seam.
  2. Xbox Series (Model 1914) Trimmer Potentiometer Sensor Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xbox Series (Model 1914) Trimmer Potentiometer Sensor Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xbox Series (Model 1914) Trimmer Potentiometer Sensor Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • One of the five 2.4 mm screws is located in the middle of the battery container.
    • You can either peel the sticker or punch a hole through the center to access the 2.4 mm screw.
    • Remove the screw in the middle using the TR8 Torx screwdriver. There are two 2.4 mm screws on both sides of the controller that you will also need to remove.
  3. Xbox Series (Model 1914) Trimmer Potentiometer Sensor Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the back panel.
  4. Xbox Series (Model 1914) Trimmer Potentiometer Sensor Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xbox Series (Model 1914) Trimmer Potentiometer Sensor Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xbox Series (Model 1914) Trimmer Potentiometer Sensor Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn the controller over and remove the front panel.
    • Remove both thumb sticks by pulling them up.
  5. Xbox Series (Model 1914) Trimmer Potentiometer Sensor Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xbox Series (Model 1914) Trimmer Potentiometer Sensor Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xbox Series (Model 1914) Trimmer Potentiometer Sensor Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn the controller over and remove the two 1.75 mm screws using the T6 Torx screwdriver.
  6. Xbox Series (Model 1914) Trimmer Potentiometer Sensor Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xbox Series (Model 1914) Trimmer Potentiometer Sensor Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xbox Series (Model 1914) Trimmer Potentiometer Sensor Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Do not use excessive force when you pry open the sensor housing since it can damage it.
    • Face the controller up, and with your tweezer, open the sensor housing by gently pushing away from the analog stick sensor.
    • Pull the old sensor wheel out of the sensor housing.
  7. Xbox Series (Model 1914) Trimmer Potentiometer Sensor Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xbox Series (Model 1914) Trimmer Potentiometer Sensor Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xbox Series (Model 1914) Trimmer Potentiometer Sensor Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Align the sensor wheel so that the sensor arms are facing upwards.
    • Insert the sensor wheel into the sensor housing.
    • Push the sensor housing back in using the spudger to close it back in.
  8. Xbox Series (Model 1914) Trimmer Potentiometer Sensor Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • You will repeat this process for the other three sensor wheels.
  9. Xbox Series (Model 1914) Trimmer Potentiometer Sensor Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox Series (Model 1914) Trimmer Potentiometer Sensor Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Push the analog sticks back into the analog stick sensors.
  10. Xbox Series (Model 1914) Trimmer Potentiometer Sensor Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox Series (Model 1914) Trimmer Potentiometer Sensor Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Screw back in the 1.75 mm screws using the T6 Torx screwdriver.
  11. Xbox Series (Model 1914) Trimmer Potentiometer Sensor Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xbox Series (Model 1914) Trimmer Potentiometer Sensor Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xbox Series (Model 1914) Trimmer Potentiometer Sensor Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the controller over and place the front panel back.
    • Turn it around and align the back panel so that the two battery terminal contacts are outside.
  12. Xbox Series (Model 1914) Trimmer Potentiometer Sensor Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Screw back the 2.4 mm screws using the TR8 Torx screwdriver.
  13. Xbox Series (Model 1914) Trimmer Potentiometer Sensor Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox Series (Model 1914) Trimmer Potentiometer Sensor Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Push the side panels back in place.
I hope this guide has been helpful!
Gelver Maldonado
crwdns2935283:004/09/25crwdne2935283:0
244 crwdns2915208:0crwdne2915208:0
CSU Los Angeles, Team 5-22, Harris Spring 2025 crwdns2935289:0CSU Los Angeles, Team 5-22, Harris Spring 2025crwdne2935289:0
CSULA-HARRIS-S25S5G22
crwdns2936751:024crwdne2936751:0 16
crwdns2936753:07crwdne2936753:0 113
crwdns2936753:030crwdne2936753:0 136
crwdns2942667:0crwdne2942667:0 149
