Xbox One X Upper Plastic Case Replacement
  1. Xbox One X Upper Plastic Case Replacement, Remove the sticker: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox One X Upper Plastic Case Replacement, Remove the sticker: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use blunt tweezers to peel off the sticker covering the right-side screw on the back of the console.
    • Before starting this guide: Turn off the device. Then, unplug any cables from the console.
  2. Xbox One X Upper Plastic Case Replacement, Remove the external screws: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a T10 Torx screwdriver to remove the two 12.6 mm–long screws located on the back of the console.
  3. Xbox One X Upper Plastic Case Replacement, Slide the upper case horizontally: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox One X Upper Plastic Case Replacement, Slide the upper case horizontally: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Rotate the console 90 degrees.
    • Pull the front of the upper plastic case horizontally toward the front of the console until it comes to a stop. This slides the clips out of the slots on the upper plastic case.
  4. Xbox One X Upper Plastic Case Replacement, Lift the upper case off the lower case: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox One X Upper Plastic Case Replacement, Lift the upper case off the lower case: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Rotate the console 90 degrees so that the back is facing you.
    • Lift up the left side of the upper plastic case (as viewed from the back of the console), stopping when it won’t lift any further.
  5. Xbox One X Upper Plastic Case Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xbox One X Upper Plastic Case Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xbox One X Upper Plastic Case Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • While continuing to hold the left side of the upper plastic case, push up on the right side to move the right-side screw boss out of the way.
    • If pushing up on the case doesn't work, try moving it in different directions until it can swing open.
    • Swing the upper plastic case open to 75 degrees.
  6. Xbox One X Upper Plastic Case Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox One X Upper Plastic Case Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Push the upper plastic case down and away from the console to remove it completely.
crwdns2935229:013crwdne2935229:0
Kyle Smith
crwdns2935283:002/01/21crwdne2935283:0
46,696 crwdns2915208:0crwdne2915208:0
crwdns2935297:0123crwdne2935297:0
crwdns2936753:07crwdne2936753:0 81
crwdns2936753:030crwdne2936753:0 399
crwdns2942667:0crwdne2942667:0 15,144
