This guide details how to remove the power supply of the Xbox One X.
Use a T9 Torx screwdriver to remove the 13mm screw which is under and to the left of the power input.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Using precision tweezers, remove the screw tab located on opposite side of the box.
Use a T9 Torx screwdriver to remove the 13mm screw revealed underneath the tab.
Orient the case so that the front of the Xbox (the side with the power button) is facing you.
Remove the top of the case by sliding the case towards you.
Using a T9 Torx screwdriver, remove the two 15mm silver screws that are holding a circuit board/panel to the side of the interior metal casing.
Using the same screwdriver, remove the 9mm black screw located farther to the right on the same circuit board/panel.
Remove the unscrewed panel from the side of the device by pulling it toward you.
Pull the upper edge of the white clip down, and then remove the white connector from the dislocated panel using precision tweezers.
On the top of the device in the corner directly above the white connector, there is an oval plate held in place by two screws.
Remove both of these 7mm screws with a Torx T9 screwdriver.
Lift the detached plate off to the side.
Use a Torx T9 screwdriver to remove the six 47mm long screws, which attach the bottom side of the outer case.
Turn the Xbox over, so that the bottom of the case is on top.
Lift the bottom of the case off of the Xbox by pulling it up and toward you.
Flip over the device again, so that the top is facing upwards.
Remove the 4 smaller 11mm screws in the lower left corner on the metal casing using a Torx T9 screwdriver.
Flip over the device again, so that the bottom is facing upwards.
Using a Torx T10 screwdriver, remove the two screws located on opposite sides of the metal casing. One is near the fan vent, and the other is near the power supply vent.
Remove the metal casing by pulling it upward, revealing the interior components of the device.
Lift and rotate the BD drive to reveal the wires that connect it to the motherboard.
Using your fingers, gently unplug the two sets of wires connecting the drive to the motherboard.
Alternatively, you can disconnect the wires from the drive-side sockets. This is much easier if you have not removed the power supply.
The BD drive should now be completely detached from the rest of the device, and it can be set aside.
Flip the console over.
Use a T10 Torx screwdriver to remove the four 11.4 mm screws securing the hard drive to the upper metal case.
Flip the console back over, keeping in mind the disc drive is loose.
Lift the disc drive up so that its metal tab is unhooked from the power supply.
Flip the disc drive over and place it on the power supply. The disc drive should end up facing the opposite direction it started in.
Unplug the bundled cable connector connecting the hard drive to the motherboard by pulling directly upward.
Unplug the SATA cable connecting the hard drive to the motherboard by pulling directly upward.
Lift the hard drive assembly up out of the upper metal case.
Flip the hard drive over so that the plastic mounting bracket is facing upward.
Use a T10 Torx screwdriver to remove the four 8.6 mm screws attaching the hard drive to the mounting bracket.
Lift the mounting bracket off the hard drive.
Unplug the hard drive connector from the hard drive by pulling parallel to the length of the drive.
Disconnect the plastic wire connector from the motherboard.
Remove the piece of foam by gently peeling it off the cooling system.
Remove the power supply by lifting it off the motherboard, while leaving its cord attached.
Set the power supply outside of the case so that the cord is no longer over the cooling system.
Remove the cooling system by lifting it vertically off of the motherboard.
Lift the metal piece connected to the cord out of the case.
crwdns2935229:09crwdne2935229:0
crwdns2944067:06crwdne2944067:0
Hola, ¿dónde podría comprar una fuente de energía? Gracias
just let mi knlw where i can buy this spares power suply becouse i checked all internet and not find
Can a power supply be dismantled also to check fuse and capacitors?
So I followed this to the letter. However at the end I was unable to remove the metal piece in Step 21 of the PSU as it was still screwed down to the frame. After going back through I noticed that a step was missing between 8 and 10. In Step 8 the 2 screws holding the metal piece shown in Step 21 to the frame are shown screwed in and yet by Step 10 they are out. There was no image highlighting which screws they ware like in Step 8.
Additionally, what size screws are those?
Also, it seems Step 8, 9 and 10 are out of order.
