crwdns2959928:0crwdne2959928:0 ↓Before you can access the inner components of the controller, you must remove the top motherboard. This guide will show you how to do this by de-soldering.
Remove the battery pack cover.
Remove batteries.
Grip the controller firmly to remove the side handles, wedging a spudger into the seam between the front and handle plates.
Pry the side plate away from the front plate by moving the spudger back and forth. You will need to do this all the way around the side plate's seam.
Use a screwdriver and punch a hole directly in the center of the label.
Remove the five 10mm screws located on the back of the controller using the TR8 Security Torx Screwdriver.
De-solder the soldered joints while holding the red and black wires down on the top motherboard.
De-solder the black and gray wires that are attached to the top motherboard.
Remove the rumble motors and set them aside.
Unscrew the two 7mm T6 screws located near the rumble motor sockets.
Firmly grip sides of motherboard near the middle.
Lift upwards while slightly wiggling the motherboard forward and backward.
crwdns2935229:030crwdne2935229:0
where can i get a top motherborde replacement??
Lol John - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Hi John,
Unfortunately, beyond the parts list given on the main page, I don't know of any other reliable links. I'd suggest Googling the part, or maybe searching on eBay.
Liam Gow - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I was only able to unscrew 2 of the Torx screws. They have a pin right in the middle that doesn't allow for the screwdriver to be fully inserted, or at all. The two screws I was able to unscrew must've had a shorter pin than the others.
Rami Girgis - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
These points on the head is what we call a security torx screw. You will need the specific T8 or T6 Security Torx Screwdriver to remove these screws.
jbagge0023 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
You can use a small flat blade screwdriver ;-)
If any of the screws are tight, the centre pin may snap, then you can just use a normal Torx bit.
Lee Houston - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
