Xbox One Wireless Controller Thumbstick Replacement
crwdns2869540:0crwdne2869540:0: 408K
31
215
910
407,515
crwdns2955950:0crwdne2955950:0: 63
crwdns2960004:031crwdne2960004:0, crwdns2960008:032crwdne2960008:0
crwdns2959984:0crwdne2959984:0: 207
crwdns2959974:0207crwdne2959974:0
crwdns2959986:0crwdne2959986:0: 35
crwdns2959982:035crwdne2959982:0
crwdns2955944:0crwdne2955944:0: 5 - 10 crwdns2931279:0crwdne2931279:0
This guide will assist you in replacing your thumbstick. If you have a rogue thumbstick, you have come to the right place.
    1. Xbox One Wireless Controller Thumbstick Replacement, Battery Pack: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the battery pack cover.
      • Remove batteries.
    2. Xbox One Wireless Controller Thumbstick Replacement, Side Handles: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox One Wireless Controller Thumbstick Replacement, Side Handles: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • We recommend using a nylon spudger for this step. A metal spudger is shown.
      • Grip the controller firmly to remove the side handles, wedging a spudger into the seam between the front and handle plates.
      • Pry the side plate away from the front plate by moving the spudger back and forth. You will need to do this all the way around the side plate's seam.
    3. Xbox One Wireless Controller Thumbstick Replacement, Screws: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox One Wireless Controller Thumbstick Replacement, Screws: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • There is a hidden screw located in the middle of the controller behind the label.
      • Use a screwdriver and punch a hole directly in the center of the label.
      • You may also lift the label if you do not want to puncture it.
      • Remove the five 10mm screws located on the back of the controller using the TR8 Security Torx Screwdriver.
    4. Xbox One Wireless Controller Thumbstick Replacement, Backplate: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the backplate.
    5. Xbox One Wireless Controller Thumbstick Replacement, Faceplate: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the faceplate.
    1. Xbox One Wireless Controller Thumbstick Replacement, Thumbstick: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox One Wireless Controller Thumbstick Replacement, Thumbstick: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove thumbsticks by pulling them up off their poles.
crwdns2935229:0207crwdne2935229:0
Garrett George
crwdns2935283:001/22/15crwdne2935283:0
6,482 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 20-15, Maness Winter 2015 crwdns2935289:0Cal Poly, Team 20-15, Maness Winter 2015crwdne2935289:0
CPSU-MANESS-W15S20G15
crwdns2935297:096crwdne2935297:0
crwdns2947412:032crwdne2947412:0
Is there any advice for a controller that has had this repair, but continues to drift? I have done this repair successfully many times, and now i have a controller that (with 2 different replacement parts) continues to drift.
Is there a reset or config I can do?
Jim - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Drift issues are a different problem you would need to solder a new joystick box to fix that this is for loose or damaged thumb sticks
myhero667 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I used a cotton ball on my Xbox one Elite to fix drifting issues.
ajcroyle - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Does anyone know the correct SKU for the joystick box for the Model 1537 in particular? And any link to purchase it. Thanks
ZuYao - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Can i apply 2 thumbsticks off the xbox 360 controller when i removed them?
Merlijn Fransen - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936751:024crwdne2936751:0 31
crwdns2936753:07crwdne2936753:0 215
crwdns2936753:030crwdne2936753:0 910
crwdns2959996:0crwdne2959996:0 407,515
