This guide provides step by step instructions to replace your controller's thumbstick successfully.
Slide the battery pack cover toward the top of the controller to remove it.
Remove batteries.
Hold firmly the controller, place the spudger into the top seam of the controller and carefully work all the way to the bottom.
Pry the side of handle away from the controller by moving the spudger back and forth around the side handle's seam.
Repeat this process for both side handles.
Using the T8 Security Torxs screwdriver, remove the five 10mm screws from the back of the controller.
One of the screws is hidden behind the label.
Select the thumbstick that you want to replace and pull it off its pole.
crwdns2935229:028crwdne2935229:0
Hello. I have an controller but it isn't working right. The right stick wont register when i push it down. I spilled cola on it. Any tips?
