Xbox One Wireless Controller 1697 Bumpers Replacement
  1. Xbox One Wireless Controller 1697 Bumpers Replacement, Bumpers: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery pack cover.
    • Remove the two AA batteries.
    • Carefully remove the sticker or puncture to reveal the screw.
    Note: Screw removal is in Step 3
    jkgarrett17 - crwdns2934203:0crwdne2934203:0
  2. Xbox One Wireless Controller 1697 Bumpers Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xbox One Wireless Controller 1697 Bumpers Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xbox One Wireless Controller 1697 Bumpers Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the side handles by wedging the spudger around the side panels.
    • Pry the side panel by moving the spudger back and forth. You must do this along the entire seam to remove the side handle panel.
    • There are seven clips that need to be opened to remove each handle panel.
    Absolutely use the spudger to do this. DO NOT just lift up a bit at the bottom and then try to forcefully pull off this panel (as is shown and suggested on *multiple* YouTube videos). You WILL snap the clips. Maybe not all of them and *maybe* none of them, but as the instructions here detail, what you want to do is UNCLIP the clips where they are located, using the PLASTIC spudger. NOT a screwdriver. I watched three separate videos on YouTube where the person said “just stick a screwdriver in there and once you’re able to lift up enough to fit your finger inside, do so, and then just carefully pull the panel off.” That’s not how it works.
    Andrew Sauk - crwdns2934203:0crwdne2934203:0
  3. Xbox One Wireless Controller 1697 Bumpers Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xbox One Wireless Controller 1697 Bumpers Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xbox One Wireless Controller 1697 Bumpers Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Removing the side handles allows access to remove the faceplate.
    • Use the TORX TR8 screwdriver to remove the five TR9 Torx screws.
    you must also remove the T8 screw hidden under the label in the battery compartment to free the faceplate.
    Dennis Kim - crwdns2934203:0crwdne2934203:0
    Precised by Dennis Kim, but to remove the screws you need a TORX TR8 screwdriver (I guess it’s a Torx size 8)
    James Burton - crwdns2934203:0crwdne2934203:0
  4. Xbox One Wireless Controller 1697 Bumpers Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xbox One Wireless Controller 1697 Bumpers Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xbox One Wireless Controller 1697 Bumpers Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Now that the bumpers are easily visible make sure to clean any dirt or grime that may be around the bumpers.
    • The bumpers are connected by a middle plastic cover that is around the Xbox home button. Remove this plastic piece by lifting the plastic cover over the two pins, pressing the home button in, and pushing the cover towards the top of the controller.
    • Be aware of the sync button loosely placed under the plastic covering. Ensure it is put back before putting back the bumper/plastic cover assembly.
    • Remove the current bumper assembly by pulling them off the plastic cover.
    you forgot to include directions for removing the central cover.
    And when you do, the connect button pops out, and now I have no clue how to put it back -_-
    Roel Binnendijk - crwdns2934203:0crwdne2934203:0
    The replacement part I bought fit OK but was too snug, with the result that the bumpers wouldn’t spring back so they wouldn’t click and unclick the tiny control switches they connect to.
    After a bit of examination I determined that if I cut out the middle arch section that joins the bumpers, but leaving enough plastic to go under the central plastic cover so that they would be held in place securely, that it was possible to reassemble the controller so the bumpers click and unclick freely.
    Perry Bonewell - crwdns2934203:0crwdne2934203:0
    I had the same issue, But i just shaved the little lugs that connect the button to the switch with a scalpel and used the original plastic black cover. Works a treat and i’ve no fear the button will fall out.. :)
    steve winter -
  5. Xbox One Wireless Controller 1697 Bumpers Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xbox One Wireless Controller 1697 Bumpers Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xbox One Wireless Controller 1697 Bumpers Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The controller is now ready for the new bumper assembly.
    • Align the new bumpers onto the top of the controller by holding down the triggers and aligning the four pins on both sides.
    • Set the new home button cover over the micro USB port, push the home button in, and pull the cover over the two pins shown.
Your device is now ready to be used.
crwdns2935229:061crwdne2935229:0
Ryan Burroughs
crwdns2935283:009/25/17crwdne2935283:0
1.178 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S9-G1, Remmell Fall 2017 crwdns2935289:0USF Tampa, Team S9-G1, Remmell Fall 2017crwdne2935289:0
USFT-REMMELL-F17S9G1
crwdns2947412:014crwdne2947412:0
the bumpers take some finesse to remove, so be patient
Vincent - crwdns2934203:0crwdne2934203:0
You should add a security hex screwdriver to your tools list, along with the gauge that is required.
Travis Weston - crwdns2934203:0crwdne2934203:0
There is a fifth screw in the battery compartment that holds the faceplate on. Take an exacto knife and cut out sticker where the hole is.
Scott Williams - crwdns2934203:0crwdne2934203:0
Could you elaborate on the “remove the bumpers” part (last step) please, thank you.
r.d.huijsmans - crwdns2934203:0crwdne2934203:0
Great guide. Helped me easily fix a sticky bumper and save 60$
Bryon Crockett - crwdns2934203:0crwdne2934203:0
Thank you soooo much. Had a broken bumper for over a year and finally fixed it thanks to this great guide.
twisted-starlight - crwdns2934203:0crwdne2934203:0
It would be nice if the reserve was shown as well.
Ryan A - crwdns2934203:0crwdne2934203:0
How do you put them back on. The right button assembly seems to be different than the left for me
GildenScale - crwdns2934203:0crwdne2934203:0
I need to fix this bumpers on this same controller, does anyone know which is the type of bumpers that I need for this controller before I buy one set? I’ve found there are 2 types, one with a curve connection, and another with a flat straight connection bewteen bumpers.Thnx
Gzamo Z - crwdns2934203:0crwdne2934203:0
Instructions were fool-proof. Although, I didn’t have a new bumper to install, I was able to take my controller apart to verify it was broken. I will say, it took some cussing to get the handles off, lol. Those sucka’s wouldn’t budge for a little bit, haha.
Jenny - crwdns2934203:0crwdne2934203:0
Bad design or planned obsolescence on Microsoft's part, but thanks for the guide. I had a problem that others had on the replacement bumper where it had the switch depressed all the time, their solution was to file down the plastic (just barely) that presses the switch and it worked for me as well.
Tony - crwdns2934203:0crwdne2934203:0
Excellent guide! Just revived a controller that had been chilling unused for 2 years. The replacement bumper I purchased off of Ebay had a little hitch. They would not move or click at all when placed. I just had to break off the little plastic nub that holds the end of the bumper to the controller (I found that little trick on accident by breaking one of them, lol). Now the controller functions fine, the bumpers can just be pulled up at the outside ends. Not a problem, as their purpose is to be clicked. Thanks!
[deleted] - crwdns2934203:0crwdne2934203:0
passen die teile auch auf einen 1708? xbox one s controller...
Jim Bean - crwdns2934203:0crwdne2934203:0
It is worth noting that you should definitely be paying attention to alignment when inserting in the new bumpers. Make sure all 8 protruding black plastic "fins" (2 on the bumpers per side, 2 on the controller itself per side) go into the correct places, otherwise this whole thing won't snap into place and obviously won't work.
All 4 plastic fins on the controller need to go into the middle channel on the underside of the bumpers. The 2 inner fins on the bumper constellation need to go underneath a black bar so that they are able to activate the buttons. The 2 outer fins need to hook underneath a black bar on the controller, this keep them in place.
I hope this is able to help those of you that might be struggling with this :)
SiYanMihou - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 14
crwdns2936753:07crwdne2936753:0 109
crwdns2936753:030crwdne2936753:0 419
crwdns2942667:0crwdne2942667:0 84,513
