crwdns2862591:0crwdne2862591:0
crwdns2862592:0crwdne2862592:0
crwdns2959928:0crwdne2959928:0 ↓This guide has only a few simple steps to get to the microphone. However, soldering is required to fully detach the microphone from the headset and install a replacement. Please refer to the soldering technique guide for instructions on soldering and desoldering.
Spudger4.9
Use the flat end of a spudger to pry out the rubber stopper at the base of the boom.
Remove the single 6 mm flathead #2.0 screw exposed after removing the rubber stopper.
Lift the joint of the boom up and over its pivot point to separate the microphone from the headset.
Using the flat end of the metal spudger, pry the back plate off the boom.
Using the flat end of the plastic spudger, gently pry the microphone out of its casing.
Desolder the two wires from the back of the microphone. For instructions on how to solder and desolder, please see the soldering technique guide.
crwdns2947412:09crwdne2947412:0
Is a replacement microphone available from iFixit?
Scott Minton - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
What do you replace the mic with?
Its Me - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
They have the microphone for sale
daniel david guerrerogarcia - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Would it presumably be just as easy to replace the microphone speaker with one from another headset, granted it fits ?
harumscxarum - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Any mod to make the cable removable?
kikis.andcream - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
