Xbox One S WiFi Card Replacement
crwdns2869540:0crwdne2869540:0: 24 k
11
70
355
24 157
crwdns2955950:0crwdne2955950:0: 24
crwdns2960004:019crwdne2960004:0, crwdns2960008:05crwdne2960008:0
crwdns2959984:0crwdne2959984:0: 22
crwdns2959974:022crwdne2959974:0
crwdns2955944:0crwdne2955944:0: crwdns2931287:05crwdne2931287:0
So you've confirmed your Xbox One S cannot connect to any Wi-Fi sources, but other devices can. Follow these steps to replace the Wi-Fi card.
    1. Xbox One S WiFi Card Replacement, Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Flip the Xbox One S so that the bottom of the case is facing upward.
    2. Xbox One S WiFi Card Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Begin by working at the case on the rear where the warranty sticker is located. Insert the plastic opening tool into the gap between the bottom of the case and the grated top side. Then find the clips in between that hold the case in place. Use the opening tool to pop the clips out. The best method is to pry the black case away from the bottom.
      • Use the opening tool to pop the clips out. The best method is to pry the black case away from the bottom.
      • You will hear clicking sounds when you are prying the case open. It may be fairly difficult to remove the bottom.
      • It's possible that the clips may break when you remove the bottom from the case.
      • We recommend starting at the back where the warranty sticker is located. Pry along the rear edge until all clips are free. From there do each side. When three sides are free start at the end of the front opposite the sync button. Be cautious and take your time and all should separate without any damage.
    3. Xbox One S WiFi Card Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Once all of the clips are opened, remove the bottom part of the case.
    4. Xbox One S WiFi Card Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox One S WiFi Card Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use a T10 Torx screwdriver to remove the six green 50 mm long screws from the metal case labeled F1 through F6.
    5. Xbox One S WiFi Card Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox One S WiFi Card Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Gently separate the interior case from the white exterior case using the appropriate method.
      • Pry the white plastic sides outwards at the rear to separate from the plastic I/O shield.
    1. Xbox One S WiFi Card Replacement, WiFi Card: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Search the sides of the interior case for the Wi-Fi card. It should be across from the hard drive.
    2. Xbox One S WiFi Card Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the black T8 screws with orange circles around them (there should be 3 of them).
      • After removing the screws, gently detach the Wi-Fi card.
crwdns2935229:022crwdne2935229:0
Victoria Law
crwdns2935283:004/26/17crwdne2935283:0
1 135 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S22-G3, Livingston Spring 2017 crwdns2935289:0Cal Poly, Team S22-G3, Livingston Spring 2017crwdne2935289:0
CPSU-LIVINGSTON-S17S22G3
crwdns2935297:0132crwdne2935297:0
crwdns2947412:05crwdne2947412:0
The T10 is too small for the WiFi card what should I use
Joe Smith - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
How long are the 15 mm screws supposed to be?
Natalie G - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
So I have replaced the Wi-Fi card from the Wi-Fi I bought from ifixit and my console cannot still connect to the Wi-Fi but my other devices can any help?
Noel Sappor - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936751:024crwdne2936751:0 11
crwdns2936753:07crwdne2936753:0 70
crwdns2936753:030crwdne2936753:0 355
crwdns2959996:0crwdne2959996:0 24,157
