This guide will show you how to remove the top panel of the interior case of the Xbox Box One S. This is necessary for the removal of either the hard drive, the disk drive, the heatsink/fan, the motherboard, or the power block.
Flip the Xbox One S so that the bottom of the case is facing upward.
Begin by working at the case on the rear where the warranty sticker is located. Insert the plastic opening tool into the gap between the bottom of the case and the grated top side. Then find the clips in between that hold the case in place. Use the opening tool to pop the clips out. The best method is to pry the black case away from the bottom.
Once all of the clips are opened, remove the bottom part of the case.
Use a T10 Torx screwdriver to remove the six green 50 mm long screws from the metal case labeled F1 through F6.
Gently separate the interior case from the white exterior case using the appropriate method.
Pry the white plastic sides outwards at the rear to separate from the plastic I/O shield.
Flip the interior case so it is fan side upward.
To access the hardware within the casing, you can pop and lift the top panel of the casing. It should come right off.
crwdns2935229:012crwdne2935229:0
Pourquoi ma X boxe One s'allume plus
Very sloppy manual. Skips removing a couple screws (such as those marked Bx like B1), says to remove certain screw, then on the next step it's back in the image. Skips removal of some elements. Overall, this guide is usable, but only just. 3 stars out of 5.
