Xbox One S Case Replacement
  1. Xbox One S Case Replacement, Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the Xbox One S so that the bottom of the case is facing upward.
  2. Xbox One S Case Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Begin by working at the case on the rear where the warranty sticker is located. Insert the plastic opening tool into the gap between the bottom of the case and the grated top side. Then find the clips in between that hold the case in place. Use the opening tool to pop the clips out. The best method is to pry the black case away from the bottom.
    • Use the opening tool to pop the clips out. The best method is to pry the black case away from the bottom.
    • You will hear clicking sounds when you are prying the case open. It may be fairly difficult to remove the bottom.
    • It's possible that the clips may break when you remove the bottom from the case.
    • We recommend starting at the back where the warranty sticker is located. Pry along the rear edge until all clips are free. From there do each side. When three sides are free start at the end of the front opposite the sync button. Be cautious and take your time and all should separate without any damage.
  3. Xbox One S Case Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once all of the clips are opened, remove the bottom part of the case.
  4. Xbox One S Case Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox One S Case Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T10 Torx screwdriver to remove the six green 50 mm long screws from the metal case labeled F1 through F6.
  5. Xbox One S Case Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox One S Case Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently separate the interior case from the white exterior case using the appropriate method.
    • Pry the white plastic sides outwards at the rear to separate from the plastic I/O shield.
crwdns2935229:041crwdne2935229:0
Christopher Chen
crwdns2935283:004/26/17crwdne2935283:0
654 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S22-G3, Livingston Spring 2017 crwdns2935289:0Cal Poly, Team S22-G3, Livingston Spring 2017crwdne2935289:0
CPSU-LIVINGSTON-S17S22G3
crwdns2935297:059crwdne2935297:0
crwdns2947412:05crwdne2947412:0
I struggled with the retention tabs the first time I opened the Xbox S. I dabbed a little Armor All on a Qtip and coated both sides of tabs with a little. Popped right open the second time, wiped Armor All on the fan blades as well to minimize dust collection.
Mike DePedro - crwdns2934203:0crwdne2934203:0
Hi!
Great review of the process! I have a question, having stripped down an rebuilt an XBox One S to extract a 500 yuan note and two peties my 7 year old inserted in the CD/DVD slop, as well as a DOA DVD drive the power switch is not working. It works if I short the contact but there appears to be a square hole in the back of the power switch (the x box logo)
Should there be a conducting contact in the back of the switch and if so, is it simply a square lump of steel or is it tapered? Would like the dimensions please.
Many thanks for taking time to reply!
Dr B
Dr John C Bullas
Southampton UK
john.bullas - crwdns2934203:0crwdne2934203:0
Hi can u fit a core i5 apple gen in Xbox one s case
Aayan Beast - crwdns2934203:0crwdne2934203:0
Excuse me but is there an everyday item that I can use to open the bottom of my Xbox one s with?
Brody Luce - crwdns2934203:0crwdne2934203:0
CAUTION: Sheared off power and pairing switches when attempting to affix to panel.
Mark - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 16
crwdns2936753:07crwdne2936753:0 147
crwdns2936753:030crwdne2936753:0 655
crwdns2942667:0crwdne2942667:0 75,942
