Xbox One S All Digital Edition Bottom Metal Shield Replacement
  1. Xbox One S All Digital Edition Bottom Metal Shield Replacement, Plastic Enclosure: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xbox One S All Digital Edition Bottom Metal Shield Replacement, Plastic Enclosure: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xbox One S All Digital Edition Bottom Metal Shield Replacement, Plastic Enclosure: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Position the iFixit Opening Tool's riveted edge in between the top and bottom cover of the plastic enclosure.
    • Apply downward pressure on the iFixit Opening Tool until the security clip unlocks.
    • Repeat on different points of the plastic enclosure until the bottom cover is removed.
  2. Xbox One S All Digital Edition Bottom Metal Shield Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox One S All Digital Edition Bottom Metal Shield Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the six 50 mm green screws (labeled F1-F6) from the metal chassis using a Torx 10 screwdriver.
    • These screws hold the top cover of the plastic enclosure to the chassis.
  3. Xbox One S All Digital Edition Bottom Metal Shield Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox One S All Digital Edition Bottom Metal Shield Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Apply pressure to peel off the sides of the casing.
    • Separate the metal chassis from the top cover, lifting the back of the chassis up and away from the top cover.
    • The plastic back panel is meant to stay attached to the metal chassis.
  4. Xbox One S All Digital Edition Bottom Metal Shield Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the metal enclosure so that the fan cover is on top.
  5. Xbox One S All Digital Edition Bottom Metal Shield Replacement, Top Metal Shield: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox One S All Digital Edition Bottom Metal Shield Replacement, Top Metal Shield: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 15mm screws from the front panel using the Torx T8 screwdriver.
  6. Xbox One S All Digital Edition Bottom Metal Shield Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xbox One S All Digital Edition Bottom Metal Shield Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xbox One S All Digital Edition Bottom Metal Shield Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully slide the top metal case off the frame.
    • This may require shifting the case side to side as you slide up.
  7. Xbox One S All Digital Edition Bottom Metal Shield Replacement, Bottom Metal Shield: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox One S All Digital Edition Bottom Metal Shield Replacement, Bottom Metal Shield: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the eight 10mm screws from the bottom of the metal casing using the Torx T9 screwdriver.
    • Remove the four 15mm screws from the bottom of the heatsink fastener using the Torx T8 screwdriver.
  8. Xbox One S All Digital Edition Bottom Metal Shield Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xbox One S All Digital Edition Bottom Metal Shield Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xbox One S All Digital Edition Bottom Metal Shield Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two plastic pieces from the motherboard.
  9. Xbox One S All Digital Edition Bottom Metal Shield Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xbox One S All Digital Edition Bottom Metal Shield Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xbox One S All Digital Edition Bottom Metal Shield Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the motherboard up from the metal chassis.
    • The motherboard should easily separate from the metal chassis.
Jules Hajjar
crwdns2935283:010/10/19crwdne2935283:0
1,897 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S12-G6, Regan Fall 2019 crwdns2935289:0Cal Poly, Team S12-G6, Regan Fall 2019crwdne2935289:0
CPSU-REGAN-F19S12G6
crwdns2935297:032crwdne2935297:0
crwdns2936753:030crwdne2936753:0 95
crwdns2942667:0crwdne2942667:0 4,169
