Xbox One Optical/Disc Drive Replacement
  1. Xbox One Optical/Disc Drive Replacement, Side Vent: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xbox One Optical/Disc Drive Replacement, Side Vent: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xbox One Optical/Disc Drive Replacement, Side Vent: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • With a plastic opening tool, pry the side vent from the console.
    • Start from the back edge and work towards the front of the console.
  2. Xbox One Optical/Disc Drive Replacement, Wi-Fi Board: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox One Optical/Disc Drive Replacement, Wi-Fi Board: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the black angled tab behind the silver button toward the back of the console and set it aside.
  3. Xbox One Optical/Disc Drive Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xbox One Optical/Disc Drive Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xbox One Optical/Disc Drive Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Rotate the Xbox and remove the warranty sticker from the back. Removing this seal and opening the case of the Xbox voids your warranty with Microsoft.
    • Use a plastic opening tool on the back to pry the top of the case from the bottom. Use an up and out motion to dislodge the clips. There are multiple clips to release on the back and two on the sides.
    • This step may take up more time than the others, keep prying with the plastic opening tool and when you release one clip, wedge something underneath it so it doesn't close again.
  4. Xbox One Optical/Disc Drive Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox One Optical/Disc Drive Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully lift the top of the case, note that there is a wire connecting the front panel to the motherboard. Take care not to break this.
    • Using a spudger, release the ribbon wire from the front panel.
    • The top case is now free, set it aside.
  5. Xbox One Optical/Disc Drive Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xbox One Optical/Disc Drive Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xbox One Optical/Disc Drive Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the speaker by squeezing the the tab on the black plastic mounting piece and lifting it up.
    • Carefully unplug the connector from the green front panel board.
    • The speaker is now free, set it aside.
  6. Xbox One Optical/Disc Drive Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox One Optical/Disc Drive Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the two 8.2mm T-9 screws securing the Wi-Fi board to the chassis.
    • Using the spudger, gently lift the antenna connector from the Wi-Fi board.
  7. Xbox One Optical/Disc Drive Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox One Optical/Disc Drive Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a spudger and a motion similar to the previous step, gently lift the antenna connector from the green board on the front.
    • Carefully pull out the clips securing the antenna wire to the chassis, releasing the wire.
  8. Xbox One Optical/Disc Drive Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully pull the Wi-Fi board straight up to release it from the chassis. The Wi-Fi board is now free.
  9. Xbox One Optical/Disc Drive Replacement, Optical/Disc Drive: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox One Optical/Disc Drive Replacement, Optical/Disc Drive: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove all eight of the 64.0 mm, T-9 screws labeled C1 through C8 securing the chassis top to the motherboard.
  10. Xbox One Optical/Disc Drive Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xbox One Optical/Disc Drive Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xbox One Optical/Disc Drive Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the chassis top, being careful not to break the wire connecting the chassis top to the motherboard.
    • Unplug the connector labeled 3 on the motherboard by gently pulling up.
    • The chassis top is now free, set it aside.
  11. Xbox One Optical/Disc Drive Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xbox One Optical/Disc Drive Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xbox One Optical/Disc Drive Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the bottom half of the chassis (motherboard and all) from the bottom half of the black case.
    • Unplug the red wire connecting the optical drive to the motherboard from its connector on the motherboard.
    • Unplug the yellow wire connecting the optical drive to the motherboard from its connector on the motherboard.
    • The optical drive is now free, lift it from the chassis and set it aside.
crwdns2935229:016crwdne2935229:0
Gwendolyn Church
crwdns2935283:001/27/14crwdne2935283:0
1 500 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 6-22, Maness Winter 2014 crwdns2935289:0Cal Poly, Team 6-22, Maness Winter 2014crwdne2935289:0
CPSU-MANESS-W14S6G22
crwdns2935297:011crwdne2935297:0
crwdns2947412:07crwdne2947412:0
Are the drives paired as the 360 ones were do we need to swap over the logic board to get game playback? Thanks
Scott Mitchell - crwdns2934203:0crwdne2934203:0
Yes they are married in the same way as the 360 is. It's not difficult at all to swap.
Fred Haschalk -
The question is do we need to swap the pcb boards or can we plug in a replacement and play media?
ooozie - crwdns2934203:0crwdne2934203:0
The instructions are good up until you take the old drive out. There is nothing mentioned about switching cards on the drives.
David - crwdns2934203:0crwdne2934203:0
i cant do this im only a kid and my dad will get mad at me if I do this
laquantis jeffery - crwdns2934203:0crwdne2934203:0
Many thanks for very clear and easy to follow instructions... carried out this task and works perfectly..
damian s - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 16,877
