Xbox One Optical Drive Laser Replacement
  1. Xbox One Optical Drive Laser Replacement, Optical Drive Case Screws: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Make sure the optical drive is not connected to any power source and is powered off.
    • Unscrew the four Phillips #1 screws on the top of the optical drive.
  2. Xbox One Optical Drive Laser Replacement, Optical Drive Case Lid: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the lid off of the optical drive case, this should require little to no force.
  3. Xbox One Optical Drive Laser Replacement, Optical Drive Case: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox One Optical Drive Laser Replacement, Optical Drive Case: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the remaining optical drive case off of the internal components.
    • Internal components often snag on these points when removing the optical drive case.
  4. Xbox One Optical Drive Laser Replacement, ZIF Connectors: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox One Optical Drive Laser Replacement, ZIF Connectors: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the three ZIF connectors on the optical drive PCB.
    • Using tweezers, gently lift the tab on each ZIF connector to release the ribbon cables.
    • Remove the ribbon cable from each ZIF connector.
  5. Xbox One Optical Drive Laser Replacement, PCB Screws: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the three Phillips #0 screws mounting the PCB.
  6. Xbox One Optical Drive Laser Replacement, Moving the PCB: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift the PCB and place it to the side.
    • When lifting the PCB, be careful to not detach the wires connecting the PCB to the motor.
  7. Xbox One Optical Drive Laser Replacement, Optical Drive Laser Screws: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the three Phillips #0 screws mounting the optical drive laser.
  8. Xbox One Optical Drive Laser Replacement, Optical Drive Laser: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the old optical drive laser from the unit and place in the new optical drive laser.
    Most replacement lasers are just the actual laser head. There are a bunch more steps required to remove the laser head from this assembly.
    Nick Exarhos - crwdns2934203:0crwdne2934203:0
    Hi, Nick! This guide was made using only tools and parts that were available at the time from iFixit. The only part available from iFixit at the time was Item # IF294-057-1 Xbox One Optical Drive Laser. This is a guide for replacing that part.
    Further repairs can be made to replace parts of the laser. I would encourage you to build off of this guide and document the process for replacing parts of the laser.
    Austin Stein -
Austin Stein
crwdns2935283:002/24/21crwdne2935283:0
259 crwdns2915208:0crwdne2915208:0
University of North Texas, Team S1-G17, Raign Spring 2021 crwdns2935289:0University of North Texas, Team S1-G17, Raign Spring 2021crwdne2935289:0
UNT-RAIGN-S21S1G17
If my xbox one is reading Bluray disc(xbox one games/ Bluray movies), but for DVD it work sometimes, sometimes it wont (xbox 360 games/ DVD), should i replace the whole bluray drive or this Optical drive laser?
Ali Kazimi - crwdns2934203:0crwdne2934203:0
I would start with this repair. A faulty laser sounds like a very likely source for your issue. If it doesn't work you have a problem with the drive board.
Replacing the entire drive would require you to replace the main motherboard of the Xbox with one from the same console that the replacement drive came from because they are linked as an anti-piracy measure. At that point you're better off replacing the entire console.
Austin Stein -
crwdns2936753:07crwdne2936753:0 35
crwdns2936753:030crwdne2936753:0 152
crwdns2942667:0crwdne2942667:0 6,401
