Xbox One Heat Sink Replacement
Andrew Optimus Goldheart
crwdns2944107:0crwdnd2944107:0Andrew Optimus Goldheartcrwdnd2944107:0crwdnd2944107:0crwdnd2944107:02crwdnd2944107:0crwdne2944107:0
crwdns2944111:0April 24, 2023crwdne2944111:0
1 - 2 crwdns2931253:0crwdne2931253:0
crwdns2937801:0crwdne2937801:0
crwdns2942287:0crwdne2942287:0
Need to upgrade to some serious cooling? Or replace a busted heat sink? Follow this guide to replace the heat sink in your Xbox One.
Note that separating the heat sink from the CPU compromises the original thermal compound. You'll need to clean off and replace the thermal paste with a new application. See this guide for directions on how to do this.
crwdns2944105:0crwdne2944105:0
  1. Xbox One Heat Sink Replacement, Upper Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    In the United States the Magnuson-Moss Warranty Act of 1975 is a Federal Law that states that stickers and clauses are illegal. It says you can open your electronics without voiding the warranty, regardless of what language of that warranty says.
    Dustin D'Amour - crwdns2934203:0crwdne2934203:0
    Stickers are illegal!?
    Brandon -
    For anyone concerned, if you apply heat with a blow dryer or heat gun you can carefully remove the sticker without damaging it, making it impossible to know that the sticker was ever removed.
    Kelton Stewart - crwdns2934203:0crwdne2934203:0
    All the immature comments aside, thank you Dustin for sharing the information.
    Wade - crwdns2934203:0crwdne2934203:0
    xbox를 열기 위해서 이러한 위조방지 테이프를 자르거나 떼어내야 합니다. 하지만 걱정 마세요. 여러분이 무언가 직접적으로 망가트리지 않는한 ms는 보증을 취소하지 않습니다.
    승대/SeungDae 정/Jeong - crwdns2934203:0crwdne2934203:0
  2. Xbox One Heat Sink Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox One Heat Sink Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a plastic opening tool to pry up and remove the plastic vent that surrounds the side USB port.
    • The vent is fairly flexible, and held in place with weak plastic clips—start prying from the back and peel it out.
    - 플라스틱 오프닝 도구를 애용해서 측면 usb 포트를 둘러싼 통풍구를 들어올려 분리하세요.
    - 이 통풍구는 무척 유연하며 연약한 플라스틱 클립으로 고정되어 있습니다. 뒤쪽에서부터 들어올려 분리하고 떼어냅니다.
  3. Xbox One Heat Sink Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox One Heat Sink Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • There is a small plastic tab that reinforces the front corner of the Xbox.
    • Slide the tab straight back and remove it.
    Do u sell that plastic tag I need it
    Brandon - crwdns2934203:0crwdne2934203:0
    Here is What's Stated in Step-3 : (There is a small plastic tab that reinforces the front corner of the Xbox.) Actually, the "Tab" is NOT SMALL at all. See the Picture: The "TAB" is the Piece that this Person has their Thumb on, is the Tab that you NEED TO SLIDE TOWARDS THE "REAR" of the Unit. You will be able to tell How this Large Tab Holds the Top and the Bottom Case Covers together. Take Note how to Replace this tab back where it Belongs, when you are putting the Case Covers back together. Hope that this comment will help you. 6-29-2017
    B.L. Spence - crwdns2934203:0crwdne2934203:0
    - xbox의 전면 모서리를 지지하는 작은 플라스틱 탭이 있습니다.
    - 뒤쪽으로 똑바로 밀어서 제거하세요.
    What is this small tab referred to as?
    What is it called i need to order one.
    James Lipsey - crwdns2934203:0crwdne2934203:0
  4. Xbox One Heat Sink Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox One Heat Sink Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the flat end of a spudger between the upper and lower case where they meet at the rear of the side vent opening.
    • There is a strong plastic clip connecting the two case halves (the first of many), so you'll need to use quite a bit of force.
    • Leave the spudger in place until you open the case completely. The clips are very springy and may cause the case to snap shut while you're working.
    prying does not work. my spudger is causing damage. my soft. plastic. spudger. and the %#*@ thing does not move. this is a common issue with the instructions on this site. you write instructions like you assume people have extensive repair experience. describe the plastic tab. add detail. because simply prying WILL damage the case. hire a %#*@ writer. cause you guys do not know how to precisely convey important detail. constant problem with tech companies actually. no writers.
    Kevin Michaels - crwdns2934203:0crwdne2934203:0
    - 벗겨낸 통풍구쪽부터 상판과 하판 사이의 틈으로 spudger의 평평한 끝을 밀어넣습니다.
    - 플라스틱 클립들이 꽤 강하기 때문에 생각보다 강한 힘을 사용해야 합니다.
    - 케이스를 완전히 열 때까지 spudger를 계속 끼워두세요. 클립이 강해서 작업도중 다시 닫힐 수도 있습니다.
    it would be very very nice that the part, that you sell, will Fix. This an ols Tutorial. The new opening tools that you sell, will not help anything, cause there is no flat sign on the side. you link these tools at this tutorial, but never tested, if the new tools work. so i tell this you, no they dont fit. Thanks for nothing.
    Zeroslammer - crwdns2934203:0crwdne2934203:0
    I ve made it this far with only a Lego membership card and a flimsier amusement park card (I'm a big year old)
    Shadow Killz - crwdns2934203:0crwdne2934203:0
    I had to use a 1/32nd flathead screw driver. In the corner to get it started push the top joint of the case down and up will simultaneously pulling up and down to seperate the seam. You will need a 3rd hand to insert the 1/32nd flathead and pry up to get the case started.
    I had a virgin never opened xbox day one og so that might be why I had to do it this way.
    KSI AZZAZLE - crwdns2934203:0crwdne2934203:0
    even the wikihow instructions are better
    Ethan Banks - crwdns2934203:0crwdne2934203:0
    It’s easier if you push the top empty area part of the plastic with your finger, and stick the spudger about 3/4” (2 cm) away from the back of the xbox and start prying. You have to do this because that is the only spot where there are no clips in the way. If you do any less or more distance, the clips are in the way, and you’ll never be able to pry open the Xbox because the tool can’t get in.
    Saul Torres - crwdns2934203:0crwdne2934203:0
    A youtube video I found explains this step better. You are meant to pull up on one half and push down on the other, this separates the two halves. Then use a spudger on the rear of the console to separate the clip right under the warranty sticker, then move down the back of the console to the other clips
    Zachary Avery - crwdns2934203:0crwdne2934203:0
    I found it easier to pull apart the pieces from the seam, pull the left side (the side on the upper half of the Xbox) down, while pulling the right side up (The side on the lower half of the xbox).
    Satyr - crwdns2934203:0crwdne2934203:0
  5. Xbox One Heat Sink Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox One Heat Sink Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The interface between the upper and lower cases is secured by several clips along the rear and remaining side of the Xbox.
    • Insert a plastic opening tool between the upper and lower case to separate the clip over the rear vent.
    - 상판과 하판 사이에 끼인 후면 단자판은 여러개의 클립으로 고정되어 있습니다.
    - 플라스틱 오프닝 도구로 후면 통풍구의 클립들을 분리하세요.
  6. Xbox One Heat Sink Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox One Heat Sink Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Keep moving along the rear of the Xbox, prying up clips.
    • Make sure the spudger stays in its blocking position—even if the case opens up enough for the spudger to fall out, the remaining clips are springy and may pull the case completely shut. Keep the spudger in the gap to protect your progress.
    - 후면을 따라서 계속 클립을 들어서 분리하세요.
    - spudger가 제대로 꽂혀 있는지 중간중간 확인하세요. spudger가 빠질정도로 케이스가 분리 되더라도 남은 클립들이 매우 탄력적이라서 방심하면 도로 닫히기 십상입니다. 원활한 진행을 위해 spudger가 잘 꽂혀서 사이를 벌리도록 유지하세요.
  7. Xbox One Heat Sink Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox One Heat Sink Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Keep popping clips. It may help to slide the plastic opening tool across the clips.
    • By the time you get to the far edge of the rear case, the top case should be ready to come off. If not, run your plastic opening tool around the corner and pop the clips along the side without the USB port.
    - 클립들을 계속해서 분리합니다. 클립들을 가로질러 플라스틱 오프닝 도구를 주욱 미는 것이 도움이 될수도 있습니다.
    - 후방 케이스를 따라 분리하면 상판이 열릴 기미가 보여야 합니다. 만약 열릴 기미가 보이지 않는다면 모서리부터 플라스틱 오프닝 도구로 분리를 시작하고 usb포트가 없는 쪽을 따라서 클립 분리를 다시 시도하세요.
  8. Xbox One Heat Sink Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xbox One Heat Sink Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xbox One Heat Sink Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Starting with the spudger you left in the crack, pry the upper case up to free the last few clips.
    • Use a plastic opening tool to pop any straggler clips that weren't freed.
    • Do not try to remove the upper case yet, as it is still connected by the front panel button cable.
    • Lift the upper case slightly and shift it to give access to the front panel board.
    I got confused here. I couldn’t unclip the front panel at all. I found out that if I open the case like a clamshell (or a book, with the front being the spine of the book) I popped right off easily.
    Omar Ramos - crwdns2934203:0crwdne2934203:0
    Yeah, I saw your comment afterwards but this is exactly what I ended up doing as well. just a note for anyone reading this be careful of the flex cable as it does seem to put a questionable amount of strain on it when you open it in this manner.
    Graham Holt -
    "Lift the upper case slightly and shift it" isn't descriptive enough for this step. Also, pictures of actually getting the front panel loose would be really helpful.
    John Poyhonen - crwdns2934203:0crwdne2934203:0
    I tried fixing my Xbox one faceplate because for some reason, and when I took it off my cable stopped working. Even after repair so now I either use a disc to turn it on or my controller.
    DiceMman - crwdns2934203:0crwdne2934203:0
  9. Xbox One Heat Sink Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xbox One Heat Sink Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xbox One Heat Sink Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The front button cable has a unique ZIF connector—pay attention to the next few steps to safely disconnect it.
    • Use tweezers to lift the blue plastic retaining loop over the white connector on the board.
    • Use the tip of a spudger to push the connector's locking tab toward the cable to unlatch it.
    I recently took my Xbox one apart to clean it and for some reason it's on for a couple minutes then it cuts off
    Ali - crwdns2934203:0crwdne2934203:0
    Or anyone else who has this problem or reads this on this thread, which is not the correct thread for this question by the way, here is a link to the forum for that. It could be any of a number of issues including overheating, Portland elation, or infestation, among others.
    Xbox One turns on then turns off after a few minutes
    Rooster Blue - crwdns2934203:0crwdne2934203:0
    Is there somewhere that I can buy a replacement zif connector
    Black Light - crwdns2934203:0crwdne2934203:0
  10. Xbox One Heat Sink Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox One Heat Sink Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers to pull the cable straight out of the connector on the board.
    • Remove the upper case.
    I broke that peice that white connector peice what can I do?
    devinthomason - crwdns2934203:0crwdne2934203:0
  11. Xbox One Heat Sink Replacement, Reassembly Instructions: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xbox One Heat Sink Replacement, Reassembly Instructions: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xbox One Heat Sink Replacement, Reassembly Instructions: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The next 4 steps are directions for reassembly. Skip them to continue with disassembly.
    • Use the flat end of a spudger to free the clips securing the front panel to the upper case.
    • Remove the front panel from the rest of the upper case.
  12. Xbox One Heat Sink Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xbox One Heat Sink Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xbox One Heat Sink Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Replace the top part of the upper case.
    • Line up the clips and press firmly to re-seat them around the perimeter.
  13. Xbox One Heat Sink Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xbox One Heat Sink Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xbox One Heat Sink Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Support the front panel near the front of the Xbox.
    • Use tweezers to replace the front button cable in its ZIF socket.
    • Use the flat end of a spudger to push the ZIF lock to the left to secure the cable.
    My Xbox stopped working after this thanks
    nathan jackson - crwdns2934203:0crwdne2934203:0
    Mine did as well, its possible it may be the same reason. For me I had to unplug and plug it back in a few times and then clean off the contacts with isopropyl alcohol. Seems simple but if you haven’t already, I would try it.
    Alex Pascone -
  14. Xbox One Heat Sink Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xbox One Heat Sink Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xbox One Heat Sink Replacement: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The lower edge of the front panel has plastic hooks that interlock with plastic hooks on the front edge of the lower case.
    • With the front panel at a 45 degree angle, interlock its plastic hooks with those in the lower case.
    • Push the top of the front panel into the Xbox, like closing a mailbox. Press firmly so that the clips securing the front panel to the upper case lock securely.
    Thanks, chief - you saved my leisure time tonight
    Jordan Hunt - crwdns2934203:0crwdne2934203:0
  15. Xbox One Heat Sink Replacement, Upper Metal Case: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xbox One Heat Sink Replacement, Upper Metal Case: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xbox One Heat Sink Replacement, Upper Metal Case: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently pull up on the speaker cable connector to disconnect it from the front panel board.
    • Be careful to pull up on the cable's connector and not the connector on the board. It's pretty flimsy and you might accidentally pull it off the board entirely.
    • Use the flat end of a spudger to disconnect the antenna cable from the front panel board.
    If this connector is broken off, will that prevent the control panel to not work at all and NOT turn on? Is there a fix or work around IF this connector is broken off?
    Michael Eh - crwdns2934203:0crwdne2934203:0
  16. Xbox One Heat Sink Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xbox One Heat Sink Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xbox One Heat Sink Replacement: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two 9.5 mm T8 Torx screws from the WI-Fi board.
    • Lift the Wi-Fi board straight up from its socket in the upper metal case.
    • Leaving the Wi-Fi board antenna cable in place, move the Wi-Fi board aside, exposing the screw labeled "C3" that was beneath it.
    When reassembling- put the outer ones on first to secure the port to the metal. Then putting the wi-fi board into the port will be easy
    Nate Ennis - crwdns2934203:0crwdne2934203:0
    Will a cracked WiFi Board affect network connectivity?
    Kyle Webb - crwdns2934203:0crwdne2934203:0
    The T9 fit but was a tad big, for me the T8 worked fine
  17. Xbox One Heat Sink Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the eight 65 mm Torx T10 screws from the top of the upper metal case.
    Two of the 8 were stripped even before attempting to remove….ugggh
    Michael Massaro - crwdns2934203:0crwdne2934203:0
  18. Xbox One Heat Sink Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox One Heat Sink Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift—but do not remove—the upper metal case.
    • The Wi-Fi board interconnect cable connects the upper metal case to the motherboard.
  19. Xbox One Heat Sink Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox One Heat Sink Replacement: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the Wi-Fi board interconnect cable from the motherboard.
    • Remove the upper metal case.
    This connector may be exceptionally difficult to remove, and it is not strictly necessary for the replacement of the hard drive if you are careful.
    Rowan - crwdns2934203:0crwdne2934203:0
    Gave up on trying to unplug this and took out the 3 torx screw that was mounting the black connector on the other end 😈 way easier
    Justin Tang - crwdns2934203:0crwdne2934203:0
  20. Xbox One Heat Sink Replacement, Hard Drive Assembly: crwdns2935265:020crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xbox One Heat Sink Replacement, Hard Drive Assembly: crwdns2935265:020crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xbox One Heat Sink Replacement, Hard Drive Assembly: crwdns2935265:020crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the hard drive SATA power and data cables from the motherboard.
    I found that it is not necessary to take out the hard drive in order to remove the front panel module. If you can lift the whole metal enclosure a little to get to the right most torx screw, then you do not need to move the hard drive.
    Taiji Saotome - crwdns2934203:0crwdne2934203:0
    Thanks for letting us know about when the open day is going to be. Will make sure get my work completed by rushmyessay before the day so I can attend it in peace.
    shuaib ahmd - crwdns2934203:0crwdne2934203:0
  21. Xbox One Heat Sink Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift and remove the hard drive tray from the Xbox.
  22. Xbox One Heat Sink Replacement, Optical Drive Assembly: crwdns2935265:022crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xbox One Heat Sink Replacement, Optical Drive Assembly: crwdns2935265:022crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xbox One Heat Sink Replacement, Optical Drive Assembly: crwdns2935265:022crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the optical drive power and SATA data cables from the motherboard.
    I their a way to replace the motherboard pins the piece that connects to the hard drive, part on the motherboard that connects to HD
    Frosted Flakes - crwdns2934203:0crwdne2934203:0
  23. Xbox One Heat Sink Replacement: crwdns2935265:023crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the optical drive assembly from the Xbox.
  24. Xbox One Heat Sink Replacement, Front Panel Board: crwdns2935265:024crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the motherboard assembly out of the lower case.
  25. Xbox One Heat Sink Replacement: crwdns2935265:025crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three 9.5 mm T9 Torx screws securing the front panel board.
  26. Xbox One Heat Sink Replacement: crwdns2935265:026crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the front panel board from its socket in the front of the motherboard.
  27. Xbox One Heat Sink Replacement, Motherboard: crwdns2935265:027crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xbox One Heat Sink Replacement, Motherboard: crwdns2935265:027crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xbox One Heat Sink Replacement, Motherboard: crwdns2935265:027crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Two black plastic screw posts posts are attached to the frame with springy plastic barbs.
    • Pinch the arms together and pull the barbs out through the frame to remove the posts.
  28. Xbox One Heat Sink Replacement: crwdns2935265:028crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox One Heat Sink Replacement: crwdns2935265:028crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 8.3 mm T9 Torx screw securing the white plastic screw post to the lower metal frame.
    • Remove the white plastic screw post from the frame.
  29. Xbox One Heat Sink Replacement: crwdns2935265:029crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the lower metal frame and motherboard assembly over, to rest on the fan.
    • Remove the following screws from the bottom of the lower frame:
    • Four 11.2 mm T10 Torx screws
    • Four 9.5 mm T9 Torx screws
  30. Xbox One Heat Sink Replacement: crwdns2935265:030crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xbox One Heat Sink Replacement: crwdns2935265:030crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xbox One Heat Sink Replacement: crwdns2935265:030crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Two small plastic plugs protrude through the rear metal case—one beneath the side USB port, and another beneath the AC in port. These plugs get caught on the lower metal case and make it hard to remove the motherboard.
    • Push the two plugs through the lower metal case.
  31. Xbox One Heat Sink Replacement: crwdns2935265:031crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the motherboard and heat sink/fan assembly out of the lower metal case.
  32. Xbox One Heat Sink Replacement: crwdns2935265:032crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox One Heat Sink Replacement: crwdns2935265:032crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the fan cable from the motherboard.
  33. Xbox One Heat Sink Replacement: crwdns2935265:033crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox One Heat Sink Replacement: crwdns2935265:033crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the tip of a small flathead screwdriver between the post and the outer edge of one arm of the X-clamp.
    • Gently rotate the screwdriver, lifting the arm of the X-clamp up and off of the post.
    I slipped here and broke a chip off the back of the board lol, idk what it is or where to get it. All I know is I have a picture
    KRTMN40 - crwdns2934203:0crwdne2934203:0
  34. Xbox One Heat Sink Replacement: crwdns2935265:034crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox One Heat Sink Replacement: crwdns2935265:034crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the same rotating technique to free one more arm of the X-clamp from its post.
    • Remove the X-clamp.
  35. Xbox One Heat Sink Replacement: crwdns2935265:035crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox One Heat Sink Replacement: crwdns2935265:035crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the motherboard off of the fan/heat sink assembly.
    • When you're reassembling your Xbox, follow our Applying Thermal Paste guide at this point to apply a new layer of thermal paste to the CPU.
  36. Xbox One Heat Sink Replacement, Heat Sink: crwdns2935265:036crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xbox One Heat Sink Replacement, Heat Sink: crwdns2935265:036crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xbox One Heat Sink Replacement, Heat Sink: crwdns2935265:036crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The fan is held onto the heat sink with four sturdy plastic clips.
    • Use a plastic opening tool to pry the two clips on one side out of the channel in the side of the heat sink.
  37. Xbox One Heat Sink Replacement: crwdns2935265:037crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox One Heat Sink Replacement: crwdns2935265:037crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Separate the heat sink from the fan.
To reassemble your device, follow these instructions in reverse order. Don't forget to apply a new layer of thermal paste to your CPU. Follow this guide to learn how.
crwdns2935229:044crwdne2935229:0
crwdns2935283:010/17/09crwdne2935283:0
509,178 crwdns2915208:0crwdne2915208:0
crwdns2935297:0407crwdne2935297:0
Staff
crwdns2935297:019,797crwdne2935297:0
crwdns2947412:05crwdne2947412:0
Can you by chance get the measurements for the heatsink such as the mounting points and height of the heatsink?
marshalljosh - crwdns2934203:0crwdne2934203:0
Hi.I've just wondering can i put a liquid metal thermal paste i think the radiator has to be copper and that's all , pluses of the procedure that liquid metal thermal paste doesn't age, and the xbox will need only fan cleaning
Kiril Angelov - crwdns2934203:0crwdne2934203:0
Do you have any tips on getting the heatsinks back bracket back on?
Tim Rauls - crwdns2934203:0crwdne2934203:0
Pry on the sides in a x formation, and when you get it on the post, just push down till you see it click in to the groove on the heatsink post
etho gamer -
Disassembled removed dust with a brush, replaced the thermal paste and reassembled in 50 minutes. Feeling like a pro lmao.
Szczepan Ciołkosz - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 15
crwdns2936753:07crwdne2936753:0 88
crwdns2936753:030crwdne2936753:0 346
crwdns2942667:0crwdne2942667:0 62,629
