You can remove the side panels with a pry tool.
Remove the 5 Torx Security Bit (TR9) screws.
Pry the panel next to the 3.5mm port.
You can pop the connector up to remove the ribbon easily.
Ribbon Cable
Remove the 2 Torx (T6) screws.
Desolder the 4 wires on each side, these control the vibrations and the RT LT.
Pull up from the "top" side of the controller on the daughterboard.
Pry the middle section up from the home button side.
Unscrew the 6 Torx (T6) screws.
Now you can remove the buttons themselves.
crwdns2935229:045crwdne2935229:0
crwdns2947412:014crwdne2947412:0
Is there any way I could just do step 8, removing the Home cover? I simply need to fix my USB port so i dont really wanna take it completely apart just for that.
jones_8515 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Desoldering the rumble motors isn't necessary, nor is removing the first motherboard. Once you get that back panel off, you're golden.
J'Anthony Joseph - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Ya hi i opened my controller and right away i don’t see ether bolt in both handles. 4 i believe to top two bottom.
Suggestions please.
Craig Amyotte - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I found using a TQ5 for the 2 motherboard screws worked the best on my controller not a T6
Mat - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Thanks for the info
EasyAsABC123 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
