You can remove the side panels with a pry tool.
Remove the 5 Torx Security Bit (TR9) screws.
Pry the panel next to the 3.5mm port.
You can pop the connector up to remove the ribbon easily.
Ribbon Cable
Remove the 2 Torx (T6) screws.
Desolder the 4 wires on each side, these control the vibrations and the RT LT.
Pull up from the "top" side of the controller on the daughterboard.
Pry the middle section up from the home button side.
Unscrew the 6 Torx (T6) screws.
Hola que tal amigo disculpa es posible sustituir esa misma placa por una de un mando one ?
