This guide will assist you disassemble your Intec 7.2" Color Game Screen attachment. Instructions may be similar to the Intec 5.4" Color Game Screen attachment although this is currently unknown.
Remove 2 rubber pads to uncover 2 hidden screws
Remove 4 #1 screws
Take a spudger and disengage the 6 retaining tabs
Remove top housing
Remove 2 #1 screws
Disconnect 4 wire harnesses
Disconnect speaker header
Disconnect header if speakers need to be removed. Otherwise, this will be done in the next step.
Remove 8 #1 screws
Disconnect 2 headers
Lift wires over retaining posts
Grab the edges of the board and lift up
Disconnect last header
Remove 4 #1 screws
Lift up on tab
Remove 3 #1 screws
Grab the edges and lift the board up
Feed wires through the hinge enough to remove board from unit
These 4 headers are soldered directly to the board
