Xbox 360 Wireless Speed Wheel Rumble Motor Replacement
  1. Xbox 360 Wireless Speed Wheel Rumble Motor Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox 360 Wireless Speed Wheel Rumble Motor Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn the controller on its backside and push the "eject" button to discharge the battery compartment door on the bottom of the controller.
    • Pull the two AA batteries out.
  2. Xbox 360 Wireless Speed Wheel Rumble Motor Replacement, Back Panel: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox 360 Wireless Speed Wheel Rumble Motor Replacement, Back Panel: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the holographic Microsoft sticker with the percision tweezers to reveal a small screw.
    • Use a T6 Torx screwdriver to remove the 1.5mm screw.
  3. Xbox 360 Wireless Speed Wheel Rumble Motor Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xbox 360 Wireless Speed Wheel Rumble Motor Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xbox 360 Wireless Speed Wheel Rumble Motor Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a spudger and pry at these three locations to detach the middle cover.
    • Pull off the middle piece cover to reveal three screws.
    • Use a T8 Torx screwdriver to remove the three 2.3mm screws.
    • Remove the cover.
  4. Xbox 360 Wireless Speed Wheel Rumble Motor Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xbox 360 Wireless Speed Wheel Rumble Motor Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xbox 360 Wireless Speed Wheel Rumble Motor Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two 90mm screws with a T8 Torx screwdriver.
    • Lift up the silver middle piece to remove.
  5. Xbox 360 Wireless Speed Wheel Rumble Motor Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xbox 360 Wireless Speed Wheel Rumble Motor Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xbox 360 Wireless Speed Wheel Rumble Motor Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to remove the silver prong.
    • With the spudger, pinch the metal spring and slowly pull up to remove.
    • Use the spudger to remove eject button.
    • Remove the screw holding in the eject button with a T8 Torx screwdriver.
  6. Xbox 360 Wireless Speed Wheel Rumble Motor Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xbox 360 Wireless Speed Wheel Rumble Motor Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xbox 360 Wireless Speed Wheel Rumble Motor Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • This step is very difficult and may require a third hand.
    • Pull the two halves apart at the bottom to detach the two latches that are holding the front and back panels together.
    • Start with one side of the controller (left or right).
    • Slide the spudger towards the end of the handles and pry the two halves apart. Do the same for the opposite side.
    • The white circular caps at the top of the controller will pop off by applying light force.
    • Pull the front and back panels apart to separate them and expose the inside of the controller.
  7. Xbox 360 Wireless Speed Wheel Rumble Motor Replacement, Battery Compartment: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xbox 360 Wireless Speed Wheel Rumble Motor Replacement, Battery Compartment: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xbox 360 Wireless Speed Wheel Rumble Motor Replacement, Battery Compartment: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the battery compartment out of the controller and set it outside of the controller.
    • Do not yank, stress, or pull on the wires for removal.
    • Use the precision tweezers to pull out the red and black wire attached to the white plug at the bottom side of the circuit board.
  8. Xbox 360 Wireless Speed Wheel Rumble Motor Replacement, Rumble Motor: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox 360 Wireless Speed Wheel Rumble Motor Replacement, Rumble Motor: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use precision tweezers to remove the red and black wires that are attached to the circuit board.
    • The rumble motors will easily lift out of the controller once the wires are detached.
Mateo
crwdns2935283:002/15/18crwdne2935283:0
73 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S16-G5, Boczar Spring 2018 crwdns2935289:0USF Tampa, Team S16-G5, Boczar Spring 2018crwdne2935289:0
USFT-BOCZAR-S18S16G5
crwdns2942667:0crwdne2942667:0 656
