crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Xbox 360 Wireless Controllercrwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. Xbox 360 Wireless Controller Teardown, Removing the first screws: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xbox 360 Wireless Controller Teardown, Removing the first screws: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xbox 360 Wireless Controller Teardown, Removing the first screws: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place the controller face down on your working surface to allow access to rear screws.
    • Take the battery compartment out.
    • Use a TR9 bit and screwdriver to remove all 7 screws.
  2. Xbox 360 Wireless Controller Teardown, Removing the back: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox 360 Wireless Controller Teardown, Removing the back: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the rear half of the controller by pulling perpendicular to the front half.
    • The battery terminals have specific grooves that they slide in and out of.
    • If the two halves do not easily separate, you can slide a spudger along the seam and/or slightly depress the left/right triggers.
  3. Xbox 360 Wireless Controller Teardown, Removing the vibration motors: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox 360 Wireless Controller Teardown, Removing the vibration motors: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Detach the vibration motor cable from the PCB.
    • DO NOT use the cable to remove from the PCB. You may damage the motor, connector, or PCB by pulling on the cable.
    • After detaching the vibration motor cable from the PCB, remove the vibration motor.
    • Utilize the same technique for the other vibration motor on the opposite side.
  4. Xbox 360 Wireless Controller Teardown, Removing the PCB: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox 360 Wireless Controller Teardown, Removing the PCB: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Make sure the front half of the controller is facing towards you.
    • The PCB should simply lift out with little to no force when being held by the areas highlighted.
    • If the PCB doesn't freely lift out, apply light consistent leverage under the highlighted area.
    • Be cognizant of the components on the opposing side of the PCB.
  5. Xbox 360 Wireless Controller Teardown: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Full IC Identification:
    • You may need to enlarge it to view the text.
  6. Xbox 360 Wireless Controller Teardown, Removing the buttons and the bumper: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xbox 360 Wireless Controller Teardown, Removing the buttons and the bumper: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xbox 360 Wireless Controller Teardown, Removing the buttons and the bumper: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently peel off the conductive rubber pads to expose the backsides of the buttons
    • Remove the A, B, X, Y, Back, Start and Guide buttons. The Guide button sleeve may also be removed.
    • You can now remove the bumper assembly at the top.
  7. Xbox 360 Wireless Controller Teardown, Removing the D-Pad: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the last two screws in the D-pad with a #0 Phillips screwdriver.
    • Use a pair of tweezers to squeeze the clips together and remove the D-pad.
  8. Xbox 360 Wireless Controller Teardown, End result: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • And here is the final result: a completely disassembled Xbox 360 Wireless Controller.
Mart-Jan
crwdns2935283:005/26/19crwdne2935283:0
305 crwdns2915208:0crwdne2915208:0
crwdns2947412:05crwdne2947412:0
Very clear, helped me clean my controller. Thank you :)
Taydolf Swiftler - crwdns2934203:0crwdne2934203:0
Hello. I just did clean one of mine that i did bye 2011. The Rumble on left end right are the opposit to this guide.
I did never disconnect them from the pcb. So ma bey its another revision or the left and right is missing.
From the back.
Small left , big right.
https://imgur.com/a/DxXdUNB
Michael Orban - crwdns2934203:0crwdne2934203:0
Se puede abrir el compartimiento de las baterias ya que no hace contacto, se pierde la señal del mando
Edgar Valle Muñoz - crwdns2934203:0crwdne2934203:0
Excellent guide. Helpful to find the 7th screw
François Larivière - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 22
crwdns2936753:07crwdne2936753:0 209
crwdns2936753:030crwdne2936753:0 1,082
crwdns2942667:0crwdne2942667:0 56,130
