crwdns2959928:0crwdne2959928:0 ↓Repair or replace faulty buttons on your Xbox 360 wireless controller.
Depress the battery release button on the top of the controller.
Remove the battery holder from the controller.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use a pair of tweezers to peel the barcode sticker from the battery compartment.
Remove the seven 9.3 mm T8 Security Torx screws securing the rear case to the front case.
crwdns2935267:0crwdne2935267:0Spudger$2.99
Insert a Spudger between the front and rear cases along the left edge of the controller.
Rotate the spudger toward the front of the controller, prying the two cases apart.
Insert a spudger between the front and rear cases, near the headphone jack.
Rotate the spudger toward the front of the controller to pry the two cases apart.
Grasp the controller by the battery compartment and the headphone jack.
Lift the battery compartment away from the headphone jack, separating the rear case from the front case and logic board.
Use the flat end of a spudger to remove the vibration motor cable, moving it upward from its socket on the logic board.
Lift the vibration motor out of the front case.
Remove the vibration motor from the other side of the controller using the same method previously described.
Lifting from the headphone jack and power plug, remove the logic board from the front case.
Remove the rubber pad from the back of the input buttons.
Using a pair of tweezers, remove the buttons from the front case.
A Button
B Button
X Button
Y Button
Start Button
Select Button
Guide Button
Using a pair of tweezers, lift the home button's LED ring out of the front case of the controller.
crwdns2935229:069crwdne2935229:0
Hello I have had an Xbox for about 1-2years and everything has been working fine until the A button on one of my controllers stopped working I don't think it has gunk or anything because I can press it down and it comes back up just that when I press it in screen nothing happens but the other buttons work fine
Saul Escalon - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Thank you for the teardown! My cat has just vomitted on my joystick…. I could have cleaned it now! I appreciate it , thanks…
Nathan St-Onge - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Has anyone ever replaced the spring contacts in the logic board???
BJ Robbins - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
