Xbox 360 S PSU Disassembly
  1. Xbox 360 S PSU Disassembly, Remove Rubber Boots/Screws: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xbox 360 S PSU Disassembly, Remove Rubber Boots/Screws: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xbox 360 S PSU Disassembly, Remove Rubber Boots/Screws: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove rubber boots
    • Remove T10 Screws
    Do yourself a favor for the stupid rubber boots that prefer to rip instead of come out of the holes. Pierce them in the center with a sharp pick, and then lift the whole thing out from the inside... they're about 1/4" deep. The rubber will kinda do the "self-healing" thing (like cutting mats) and close the hole after removing the pick.
    Daniel - crwdns2934203:0crwdne2934203:0
    Good tip, it may work better towards the edge where the rubber is thinner
    Dsr -
  2. Xbox 360 S PSU Disassembly, Cooling Fan Cable: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox 360 S PSU Disassembly, Cooling Fan Cable: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the top shell, flip it over, and place next to lower shell
    • The two halves are connected together via the cooling fan wire. BE GENTLE when separating them
    • In typical Microsoft fashion, they've made it complicated to remove the fan wire. Not only is it wedged between two transistors it's also adhered with an epoxy like substance.
    • Using a craft knife, carefully cut through the epoxy to get the cable free. Work slowly and carefully. The thick substance and awkward angles make this a slightly tedious process
    • Be VERY CAREFUL. You can easily cut the cable here accidentally. If you cut your red/black wires you'll have to patch them. "Slow is smooth, smooth is fast"
  3. Xbox 360 S PSU Disassembly, Cooling Fan Assembly: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xbox 360 S PSU Disassembly, Cooling Fan Assembly: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xbox 360 S PSU Disassembly, Cooling Fan Assembly: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove PH2 screws
    • Remove PH1 screws
    • Removal unnecessary
    • Disconnect cooling fan plug
    • Pull wire through
  4. Xbox 360 S PSU Disassembly, Fan Disassembly: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xbox 360 S PSU Disassembly, Fan Disassembly: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xbox 360 S PSU Disassembly, Fan Disassembly: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove tape in order to remove fan from its housing unit. This also uncovers a hidden screw.
    • Remove 4 PH0 screws
    • Tape will need to be replaced during reassembly. Electrical or kaptom tape will suffice
    • Take note of the amount of filth collected on this fan. Inadequate cooling could kill your supply, or worse, become a fire hazard
    • Remove fan upper housing plate
    • Gently lift the fan up and over the post
  5. Xbox 360 S PSU Disassembly, Fan Model Info: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Fan model info in case you need to search out new parts
  6. Xbox 360 S PSU Disassembly, Repair Fan Cable If Necessary: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox 360 S PSU Disassembly, Repair Fan Cable If Necessary: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The fans +/- wires are covered by a thin protective sleeve.
    • Apply some electrical or kaptom tape to patch it if necessary.
    • Initially I tried to use shrink tubing here but the smallest diameter I could get around the plug was a 3/8" tube which will not properly seal around the cable when heated
    • If you accidentally cut through the entire cable (+/- wires) you'll have to resolder them together and cover with shrink tubing.
  7. Xbox 360 S PSU Disassembly, Underside Of PCB: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove PCB from lower shell and place face down
    • The metal shield must be removed in order to expose the bottom of the power supply PCB
    • To quickly and safely remove I suggest using ChipQuik on the 2 single sided through holes. Alternatively you can use solder wick
crwdns2935229:023crwdne2935229:0
Navy Vet 2015
crwdns2935283:006/25/15crwdne2935283:0
7 660 crwdns2915208:0crwdne2915208:0
If anyone else is wondering how to turn on the 12V supply, you short the 2 small center pins together. The outer rings are ground, and the inner rings are the +12V. The two small pins are the +5Vsb and the 12V enable pin, which turns on the 12V when pulled up to 5V
kjkj kjkjk - crwdns2934203:0crwdne2934203:0
Greetings, friend. Hey, I have an Xbox 360 Slim power supply that outputs 16V at 12V. Any suggestions? The power supply is an A10-120N1A board, A120R001L.
Alpacino - crwdns2934203:0crwdne2934203:0
Hola, amigo. Tengo una fuente de alimentación para Xbox 360 Slim que genera 16 V a 12 V. ¿Alguna sugerencia? La fuente de alimentación es una placa A10-120N1A, A120R001L.
crwdns2936751:024crwdne2936751:0 9
crwdns2936753:07crwdne2936753:0 63
crwdns2936753:030crwdne2936753:0 285
crwdns2942667:0crwdne2942667:0 13,157
