Xbox 360 S Left Case Replacement
Matthew Newsom
crwdns2944107:0crwdnd2944107:0Matthew Newsomcrwdnd2944107:0crwdnd2944107:0crwdnd2944107:08crwdnd2944107:0crwdne2944107:0
crwdns2944111:0Mha 20, 2024crwdne2944111:0
crwdns2931273:0crwdne2931273:0
crwdns2937803:0crwdne2937803:0
crwdns2942287:0crwdne2942287:0
Make your Xbox 360 S look shiny and new by replacing the outer panels.
  • Spudger
    Spudger
crwdns2944105:0crwdne2944105:0
  1. Xbox 360 S Left Case Replacement, Hard Drive: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xbox 360 S Left Case Replacement, Hard Drive: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xbox 360 S Left Case Replacement, Hard Drive: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Orient the Xbox 360 S so that the bottom of the console is facing toward you.
    • Push the latch holding down the hard drive cover to the left.
    • Pull the hard drive cover away from the console.
  2. Xbox 360 S Left Case Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xbox 360 S Left Case Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xbox 360 S Left Case Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Firmly grasp the fabric tab labeled with the size of the hard drive (e.g. "250 GB") attached to the hard drive.
    • Pull the hard drive straight out of the console.
    • The fabric tab is attached to a catch further inside the hard drive housing. It will take some force to pull the hard drive out.
    If i buy a new xbox 360 and replace the hardrive inside with my own, will i have my account and saves? or will i have to recover my account and start over?
    yamboboy - crwdns2934203:0crwdne2934203:0
    You will still have your saves and account if you replace your hard drive in the new xbox
    Robert Miller -
    hola tengo un disco de laptop y quiero ponerle 100 juegos como puedo hacer la xbox me reconose el disco y todo lo configuro pero cuando conecto a mi pc para pasar los juejosel emulador no me deja
    Cesar Tourreilles - crwdns2934203:0crwdne2934203:0
    My fabric was accidentally ripped off years ago. What do I do?
    org 2026 - crwdns2934203:0crwdne2934203:0
    Stick another bit on there
    Josh Cool -
  3. Xbox 360 S Left Case Replacement, Bottom Panel: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • In the following steps, you will remove the bottom vent.
    • It is attached to the bottom panel by the seven clips shown.
  4. Xbox 360 S Left Case Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox 360 S Left Case Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Orient the Xbox 360 S so that the hard drive port is facing up and the faceplate is facing to the left.
    • Insert a metal spudger between the black bottom vent and the silver rim of the bottom bezel, in the rear right corner of the vent.
    • Rotate the spudger away from the console, prying the vent up from the bottom bezel.
    • Be sure to rotate the spudger far enough so that the clips on the vent are lifted past the silver rim of the bottom bezel.
  5. Xbox 360 S Left Case Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xbox 360 S Left Case Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xbox 360 S Left Case Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • In the same manner as described above, pry the two remaining clips on the bottom right edge.
    • All of the clips along both the right and front edge should now be free. If other clips have come undone as well, that is fine.
    My xbox 360 slim is turning on but no display
    Abdul Azeem - crwdns2934203:0crwdne2934203:0
  6. Xbox 360 S Left Case Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox 360 S Left Case Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the bottom vent by lifting it away from the bottom bezel.
  7. Xbox 360 S Left Case Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox 360 S Left Case Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • In the following steps, you will remove the bottom bezel, which is attached to the rest of the console by the four clips shown.
    • The clips shown in red can be detached by inserting a metal spudger underneath the bottom edge of the clip. Once underneath the bottom edge, simply prying away from the console will free the clip.
  8. Xbox 360 S Left Case Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox 360 S Left Case Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a metal spudger through the slit near the rear left corner of the bottom bezel.
    • Rotate the spudger away from the device while lifting the rear bezel up with the other hand.
    • You may hear a "pop" signifying the clip has cleared its catch.
    These are pretty awkward to remove, but once you understand how they work its easy enough. The goal here is to slot the spudger THROUGH the gap of the silver tabs (visible in previous steps image, circled) and then pry. Put pressure against the wall of the Xbox case and push downwards, once you feel the spudger slot in, then apply force away from the Xbox and pull up a little with your free hand.
    Spaced Invader - crwdns2934203:0crwdne2934203:0
  9. Xbox 360 S Left Case Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox 360 S Left Case Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a metal spudger through the left middle slit of the bottom bezel, and between the bottom edge of the clip and the left case.
    • Simultaneously pull the bottom bezel up and rotate the spudger away from the console to free the clip.
    • In a similar fashion, free the clip at the front of the bottom bezel's left edge.
    • The entire left side of the bottom bezel should now be free.
  10. Xbox 360 S Left Case Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox 360 S Left Case Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn the console around so that the faceplate is facing to the right and the right case is facing toward you.
    • Insert the spudger into the rear-most slit on the right edge of the bottom bezel, and wedge it behind the clip by pushing the spudger down while pushing the tip of the spudger against the right case.
    • Simultaneously release the clip and pull the bottom bezel up.
    • This clip is especially hard to remove. Some force will be required to insert the spudger correctly.
  11. Xbox 360 S Left Case Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • This clip does not have a slit in the bezel to guide you. You can locate the clip by looking under the bezel near the hard drive slot.
    • Insert a spudger between the silver rim and bottom bezel directly above the clip shown.
    • Release the clip while pulling up on the bottom bezel.
  12. Xbox 360 S Left Case Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox 360 S Left Case Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • This clip is smaller than the others and should not be removed from above like the others.
    • Lift the left edge of the bottom bezel up enough to gain clearance.
    • Insert a metal spudger behind the left edge of the last clip, and push the clip away from the right case.
  13. Xbox 360 S Left Case Replacement, Top Panel: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • In the following steps, you will remove the top vent, secured to the top panel by the thirteen clips shown.
    • Take care when removing the fan vent not to break any of the plastic clips.
    The motherboard and the disc drive's PCB (circuit board) are paired. If the drive's PCB is fine, which it most likely is, then all you need to do is swap out the PCB on the new drive with your old one before installing it. No motherboard replacement required.
    Only in the unlikely case that the drive's PCB is fried will you require a full drive and motherboard replacement.
    SirStephenH - crwdns2934203:0crwdne2934203:0
  14. Xbox 360 S Left Case Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox 360 S Left Case Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Orient the console so that the words "XBOX 360" on the sides are right-side up, and the faceplate is facing to the left.
    • Insert a metal spudger between the top vent and the top bezel near the rear of the Xbox.
    • Rotate the spudger away from the console, prying the edge of the fan vent up until the two plastic clips come free.
    • Be sure to rotate the spudger far enough so that the plastic clips clear the silver rim of the top bezel.
    Whoever gave that tool the name “spudger” needs to be shot in the face.
    Richard - crwdns2934203:0crwdne2934203:0
    This step is and the others following are to rough and not needed, simply put smth in between the lamellar and push it up with littlebit pressure thats better for the plastic parts.
    TheSupport - crwdns2934203:0crwdne2934203:0
  15. Xbox 360 S Left Case Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xbox 360 S Left Case Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xbox 360 S Left Case Replacement: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a metal spudger between the fan vent and top bezel along the left side of the console.
    • In the same manner described above, begin prying the left side of the top vent away from the top bezel.
    • Continue prying along the left side of the device, freeing all the clips on that side.
  16. Xbox 360 S Left Case Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox 360 S Left Case Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the fan vent up from the freed left side to disengage the clips along the right side.
    • Remove the entire fan vent.
  17. Xbox 360 S Left Case Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox 360 S Left Case Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • In the following steps, you will be releasing the six clips highlighted in red.
    • Each clip can be undone by inserting a metal spudger underneath the bottom edge of the clip. Once underneath the bottom edge, simply prying away from the console will free the clip.
    see the red boxes specially in image
    Restrict - crwdns2934203:0crwdne2934203:0
  18. Xbox 360 S Left Case Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox 360 S Left Case Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Orient the console so that the left case is facing toward you and the faceplate is facing toward the right.
    • Insert a metal spudger through the front-most slit on the left edge of the top bezel and between the bottom edge of the clip and the left case, as described above.
    • Simultaneously rotate the spudger away from the console and pull up on the top bezel to free the clip.
    • You will hear a "pop" signifying that the clip cleared its catch.
    So I got the fan filter thing off, but the black edge plate thing isn't coming off. All I did was warp my flathead screwdriver and scratch the console.
    HumidTater - crwdns2934203:0crwdne2934203:0
  19. Xbox 360 S Left Case Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox 360 S Left Case Replacement: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the same method described above, free the two remaining clips along the left edge of the top bezel.
  20. Xbox 360 S Left Case Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Grab the entire top panel with your hands, lift up the entire left edge high enough to rest the separated clips on top of the left case.
    • You may have to go back with a spudger and undo any clips that have re-attached.
    • The top panel will not come free of the console yet.
  21. Xbox 360 S Left Case Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox 360 S Left Case Replacement: crwdns2935265:021crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Rotate the console so that the rear of the Xbox 360 S is facing to the right, and the right case is facing you.
    • Insert a metal spudger through the rear-most slit on the right edge of the top bezel and between the bottom edge of the clip and the right case.
    • While lifting up on the top bezel with your fingers, rotate the spudger away from the console to free the clip.
  22. Xbox 360 S Left Case Replacement: crwdns2935265:022crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox 360 S Left Case Replacement: crwdns2935265:022crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • In the same manner as described in the previous steps, release the middle and front clips along the right edge of the top panel.
  23. Xbox 360 S Left Case Replacement: crwdns2935265:023crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the top panel off the device.
    • You may have to go back with a spudger and undo any clips that have re-attached to the console.
  24. Xbox 360 S Left Case Replacement, Left Case: crwdns2935265:024crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Opening your Xbox 360 any further will require breaking or removing the warranty sticker on the outer case. Your Microsoft warranty for any components not directly attached to the logic board will likely be voided by removing this seal.
    Does not void the warranty in the United States according to the FTC that sent a cease and desist letter directly to Microsoft about this exact issue.
    Jeff - crwdns2934203:0crwdne2934203:0
    Thanks for the information
    Rydert -
  25. Xbox 360 S Left Case Replacement: crwdns2935265:025crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox 360 S Left Case Replacement: crwdns2935265:025crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Orient the console right-side up, with the faceplate facing toward you.
    • Locate the two clips connecting the right and left case along the top edge of the console, behind the Wi-Fi card.
    • While pushing the left and right case away from each other with one hand, pry the clips away from the case with a metal spudger.
    Retiring the WiFi module, this task gets a lot easier
    Luismi Carmona - crwdns2934203:0crwdne2934203:0
  26. Xbox 360 S Left Case Replacement: crwdns2935265:026crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox 360 S Left Case Replacement: crwdns2935265:026crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Continue to hold the two cases apart to prevent the clips reattaching.
    • Insert a spudger between the right and left cases to hold them separate while you work elsewhere.
  27. Xbox 360 S Left Case Replacement: crwdns2935265:027crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox 360 S Left Case Replacement: crwdns2935265:027crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the Xbox over so the faceplate is facing left, and the left case is facing toward you.
    • While pushing the left and right cases apart with one hand, free one clip located beside the hard drive slot.
  28. Xbox 360 S Left Case Replacement: crwdns2935265:028crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox 360 S Left Case Replacement: crwdns2935265:028crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Continue to hold the cases apart to prevent the clips from reattaching.
    • Place another spudger between the left and right cases directly below the clip.
  29. Xbox 360 S Left Case Replacement: crwdns2935265:029crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xbox 360 S Left Case Replacement: crwdns2935265:029crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xbox 360 S Left Case Replacement: crwdns2935265:029crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the flat edge of a metal spudger between the left and right cases where the warranty sticker used to be.
    • Pry the left case upwards to form a gap between the two cases, and slide the spudger in toward the left case.
    • Rotate the spudger upward to release the last clip.
    • The spudgers holding the top and bottom clips apart may be removed.
    if you make a hole right here like the link`s picture you can boot the lock
    https://scontent-mia.xx.fbcdn.net/hphoto...
    Midguet Garcia - crwdns2934203:0crwdne2934203:0
    As the user above me said, please avoid doing it like shown in the guide. It just didn’t work on my Xbox (unless your goal is to destroy the plastic case). Instead, pick some small needle like object (the spudger was too short for this, I used the SIM bit of my iFixit driver kit) and find the right spot on the big sticker which is on the left in the pictures shown in the guide. That spot is just between the text and the column of logos (Dolby Digital, etc.) (https://team-xecuter.com/slim/slim_secre..., picture not mine). Poke it (don’t be too gentle, you have to apply some force) and you will hear the clip release.
    Davide Volta - crwdns2934203:0crwdne2934203:0
    Both the above links are dead, i used this YouTube video which shows you the process of getting the hidden clip
    https://youtu.be/dFD94d6mDFE
    Kenny Montgomery - crwdns2934203:0crwdne2934203:0
    I was able to open it by pushing on the sticker to unclamp the clip while another person helped me pull open the case.
    StellularWolf51 - crwdns2934203:0crwdne2934203:0
    Here is a Video that shows the small hole behind the sticker, ist in german but ist good to see how to open that hidden clip easiely.
    https://www.youtube.com/watch?v=Bsy5IUVg...
    Michael Buß - crwdns2934203:0crwdne2934203:0
    None of the above options by the other commenters worked for me, but I found a video that points out there's a little hole right in the middle of the "SEE PRINTED MANUAL" and "UL" on the sticker under the Xbox 360 warranty sticker that I stuck a sewing needle into and it unlatches the latch: https://youtu.be/7mC8ckDvKqc?si=CVyCszpF...
    Camuise - crwdns2934203:0crwdne2934203:0
  30. Xbox 360 S Left Case Replacement: crwdns2935265:030crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox 360 S Left Case Replacement: crwdns2935265:030crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Release one clip in the front left corner of the top edge securing the left case to the faceplate.
    On earlier Xbox 360 S systems, the screws mentioned in step 40 need to be unfastened in order to complete this step
    Synapse - crwdns2934203:0crwdne2934203:0
  31. Xbox 360 S Left Case Replacement: crwdns2935265:031crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox 360 S Left Case Replacement: crwdns2935265:031crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the console over so the bottom is facing upward.
    • Release one clip in the front left corner of the bottom edge securing the left case to the faceplate.
    • Rotate the left case away from the device to release the last two inner clips.
    • Remove the left case.
crwdns2935229:028crwdne2935229:0
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0
Matthew Newsom
crwdns2935283:001/05/10crwdne2935283:0
41 471 crwdns2915208:0crwdne2915208:0
crwdns2935297:067crwdne2935297:0
Prying the top and bottom case apart with a metal spudger?, you'll ruin your xbox 360 slim case....your already voiding your warrenty, why not open it the right way??, their's is a pin-hole located at the back where the sticker is, just stick a pin into it and it will release that clip thats holding it together!
if you are going to do something like open your xbox360, do it right the first time.......
loc125 - crwdns2934203:0crwdne2934203:0
ATTENTION: The metal spudger is absolutely wrong for that second tab, you will never reach it. Instead, place your thumb over where the security sticker is on the top half of the case and apply pressure, the tab will snap out of place with the right amount of gradual force. This drove me nuts for an hour and I found the solution elsewhere.
anthonyshannontucker - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 25
crwdns2936753:030crwdne2936753:0 135
crwdns2942667:0crwdne2942667:0 23,042
